Syntax for whatever keys are selected
scott.hortonVFEUU
Observer Observer
Message 1 of 1
scott.hortonVFEUU
Observer
Observer
Hi all!
This should be a slam dunk easy thing for you, but "what would be the syntax for the selected keys on a selected object, be a group or single object?
For example, I just want to make a script that changes two values on the TCB position controller.  I go to the Listener and find what lines are being run for the values I want to use.   After changing the values, I grabbed these...
$.pos.controller.keys[2].easeTo = 20
$.pos.controller.keys[2].continuity = 0
So there is a "2" in the array because I was manipulating the 2nd key on that object.   I want to be able to replace the "2" with something so the script can be used on say the fourth key or the sixth key.   Is it the $?
A second question that I just thought of...what would the syntax be to check if the object selected even had the correct controller, like
if($selected.pos == null)
     return;
else
Thanks for looking (and hopefully having an answer).
Replies (0)
