- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm trying to get this to work ...
https://www.scriptspot.com/bobo/mxs5/pflow/pflow__Chunks_Basics.htm
on ChannelsUsed pCont do ( pCont.useAge = true pCont.useTM = true pCont.useShape = true ) on Init pCont do ( global formulaeArray = $f2_* as array ) on Proceed pCont do ( t = pCont.getTimeStart() as float if t < 0 do ( NumPos = formulaeArray.count for i = 1 to NumPos do ( pCont.AddParticle() pCont.particleIndex = pCont.NumParticles() pCont.particleAge = 0 pCont.particleTM = formulaeArray[i].transform pCont.particleShape = formulaeArray[i].mesh ) ) ) on Release pCont do ( )
It works as far as
The particles are positioned correctly at the meshes' positions without this line. But if I add that line specifying the mesh, each particle is shifted away from the "parent" meshes. They're offset and spread out.
Any idea what could be causing it?
Mark
