particles at mesh positions
mark_aldred
mark_aldred
I'm trying to get this to work ...
https://www.scriptspot.com/bobo/mxs5/pflow/pflow__Chunks_Basics.htm
on ChannelsUsed pCont do
    pCont.useAge = true
    pCont.useTM = true
    pCont.useShape = true
on Init pCont do
    global formulaeArray = $f2_* as array
on Proceed pCont do
    t = pCont.getTimeStart() as float
    if t < 0 do
        NumPos = formulaeArray.count
        for i = 1 to NumPos do
            pCont.AddParticle()
            pCont.particleIndex = pCont.NumParticles()
            pCont.particleAge = 0
            pCont.particleTM = formulaeArray[i].transform
            pCont.particleShape = formulaeArray[i].mesh
on Release pCont do
It works as far as
The particles are positioned correctly at the meshes' positions without this line. But if I add that line specifying the mesh, each particle is shifted away from the "parent" meshes. They're offset and spread out.
Any idea what could be causing it?
Mark
mark_aldred
My fault. I didn't read the part about preparing the meshes.
Works when I do that.
