.NET ParamBlock Ints and INode custom validators
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm working on a Max .Net modifier plugin. The info on max .net is a bit scarce. There is info on the web how to implement parameters, but all the information I can find only describes how to make a float .
When I try to implement an int, using a similar autoUI flag for the block, the parameter simply does not appear. I.e. something of the like:
paramBlockDesc.AddParam(0,
new object[] {
"Degree", // Parameter name
ParamType2.Int, // Parameter type
ParamBlock2Flags.Animatable, // Parameter block flags associated with parameter
0, // Resource id of parameter name (int)- should be 0,
3, //Default
1, 4 //Min and max
Furthermore, I'd like to implement an INode picker button with a custom validator. Although, an INode itself works, I can't pass a validator in any way. Using the Class, sClass and CanConvert flags (i.e. to try and implement a simpler validator by class, etc) also doesn't work.
Interestingly enough, when using ParamOption to alter a simple option that was already defined, it seems to alter the default, the value doesn't get passed (i.e. the parameter then snaps to the lower value in the range). Ex:
paramBlockDesc.ParamOption(0, (System.Int32)ConstTypes.ParamTags.p_default, new object[] { 0.5f } );
I'd imagine these can't simply be passed to unmanaged code. Do parameter options need a wrapper?
Any info and examples would be much appreciated as I've been stuck with this for some time now. Thanks!
