Maxscript to Photoshop: Can't find correct argument for Selection.Select()
TurboChiken
TurboChiken
I'm learning to manipulate Photoshop through Maxscript, and I'm just trying to select a specific area of the Photoshop document using [document].Selection.Select [region]. But I can't figure out how to pass the [region] argument, everything I try kicks an error of some kind. Does anyone have experience with this?
ps = CreateOLEObject"Photoshop.Application" -- launches Photoshop
doc = ps.application.documents.add 200 200 -- create a new document, 200 by 200 pixels
doc.Selection.Select #(0, 0, 100, 100) -- attempt to select an area, but it kicks an error
A娘
if the area was empty ,select was forbidden
TurboChiken
I wasn't able to get .select() to work, but I was able to write a workaround function by selecting the entire canvas, scaling the selection down to the correct size, and then translating it as needed:
-- Given a document reference, this selects the given area. x1 and y1 are the top left, and x2 and y2 are the bottom right.
-- Couldn't figure out how to use the .select() command, so we're using a workaround by selecting everything, then resizing and translating.
fn selectArea doc x1 y1 x2 y2 = (
	doc.selection.selectAll()
	local arr=doc.selection.bounds.dataArray
	local currWidth=arr[3]-arr[1], currHeight=arr[4]-arr[2]
	local newWidth=x2-x1, newHeight=y2-y1
	local scaleX=newWidth/currWidth*100, scaleY=newHeight/currHeight*100
	doc.selection.resizeBoundary (scaleX) (scaleY) 1 -- 1 means anchored in top left
	doc.selection.translateBoundary x1 y1
