MAXScript Qt UI
MAXScript Qt UI
Swordslayer
Advisor Advisor
Message 1 of 24
MAXScript Qt UI
Swordslayer
In the end, using Qt from MAXScript was more straightforward than I thought, kudos to @denisT.MaxDoctor for setting me on the right track with the QtUiLoader. Here's an edited sample from the max python sample scripts:
	local QFile = (python.import "PySide2.QtCore").QFile
	local QUiLoader = (python.import "PySide2.QtUiTools").QUiLoader
	local GetQMaxMainWindow = (python.import "qtmax").GetQMaxMainWindow
	local ui_file = QFile "QtTest.ui"
	ui_file.open QFile.ReadOnly
	local ui = (QUiLoader()).load ui_file (GetQMaxMainWindow())
	ui_file.close()
	fn hello = messageBox "Hello world!"
	ui.pushButton.clicked.connect hello
	ui.toolButton.clicked.connect getSaveFileName
	ui.show()
Put it in the same folder as the .ui file from the attached zip and run the ms file. The two buttons are connected to maxscript functions, I guess you get the idea. Have fun 🙂
Replies (23)
Message 21 of 24
thought the question was related to this thread enough...
anyway:
https://forums.autodesk.com/t5/3ds-max-programming/maxscript-qt-close-event/td-p/10725223
Message 22 of 24
denisT.MaxDoctor
In my experience, some "nested" topics (questions) are very easy to get lost, and it is often more difficult to find a similar but more specific question / answers in a generically named topic ("Using MXS with Python", "Qt UI", "Script Controllers", etc.).
(also the tag "solved" can be received only by the question of the author of the topic and is determined by the author)
Message 23 of 24
okay, thank you for the clarification, makes sense 😉
Message 24 of 24
FranciscoHermida
Fantastic topic, thank you for sharing!
www.boxofapps.com
