Dotnet can't access #userScripts or #userMacros
TurboChiken
TurboChiken
Years ago I wrote a script that was saved in the max installation folder, but now I'm trying to do things properly and move it to the #userscripts folder. Unfortunately every time I use (dotNetClass "System.Drawing.Image").fromFile to load a bitmap image from #userScripts or #userMacros, it kicks an exception. Can anyone confirm this is an issue, and is there a reasonable workaround? Thanks.
shawnolson
Can you post the full line you are using (including the string you are passing to the FromFile() method)?
shawnolson
You could always wrap your path with pathConfig.convertPathToAbsolute() as in this example:
(dotNetClass "System.Drawing.Image").fromFile (pathConfig.convertPathToAbsolute "$maps\uv-grid.png")
TurboChiken
Hi, Shawn, sorry for the late reply (crunching for deadlines... sigh)
Your suggestion worked! For some reason, if I used this:
(dotNetClass "System.Drawing.Image").fromFile "$userMacros\\testimage.tif"
I would get the error in the listener, "Runtime error: .NET runtime exception: $userMacros\testimage.tif". But when I wrapped it as you suggested, it works fine. Not sure what's up with that, but thank you.
