MAXScript Qt UI
MAXScript Qt UI
Swordslayer
Advisor Advisor
Message 1 of 24
MAXScript Qt UI
Swordslayer
In the end, using Qt from MAXScript was more straightforward than I thought, kudos to @denisT.MaxDoctor for setting me on the right track with the QtUiLoader. Here's an edited sample from the max python sample scripts:
	local QFile = (python.import "PySide2.QtCore").QFile
	local QUiLoader = (python.import "PySide2.QtUiTools").QUiLoader
	local GetQMaxMainWindow = (python.import "qtmax").GetQMaxMainWindow
	local ui_file = QFile "QtTest.ui"
	ui_file.open QFile.ReadOnly
	local ui = (QUiLoader()).load ui_file (GetQMaxMainWindow())
	ui_file.close()
	fn hello = messageBox "Hello world!"
	ui.pushButton.clicked.connect hello
	ui.toolButton.clicked.connect getSaveFileName
	ui.show()
Put it in the same folder as the .ui file from the attached zip and run the ms file. The two buttons are connected to maxscript functions, I guess you get the idea. Have fun 🙂
Replies (23)
Message 2 of 24
denisT.MaxDoctor
	ui_file.close()
	ui.show()
Very nice snippet!
I'm pretty far from it now, but I've tried ...
local GetQMaxMainWindow = (python.import "qtmax"). GetQMaxMainWindow
it doesn't work for me in 2020. no "qtmax".
Also I couldn't connect mxs function like:
fn format_time = (format "time:% \ n" (timestamp ()))
it connects but does not printout
Another question about UNDO for connected functions.
defining them as:
fn something = undo on (...)
it is not a good practice. any ideas?
Message 3 of 24
Swordslayer
In 2020, it'd be MaxPlus instead of qtmax.
As for printing, I guess you'd have to use python print for the output, this works in 2021:
local py = python.import "builtins"
fn format_time = py.print (py.str.format "time: {0}" (timeStamp()))
In 2020, that'd be python.import "__builtin__" instead.
As for the undo, neither that nor automatic redraw are there so yeah, I guess that would be the way to go.
Message 4 of 24
Swordslayer
Here's a bit more functional snippet using the same .ui file:
	if isProperty ::testDialog #close do testDialog.close()
	global testDialog = (QUiLoader()).load ui_file (GetQMaxMainWindow())
	ui_file.close()
	local filename
	fn print_filename = py.print (py.str.format "filename: {0}" filename)
	fn get_filename = filename = getOpenFileName()
	testDialog.pushButton.setText "Print filename"
	testDialog.pushButton.setToolTip "Click the '...' button to pick file."
	testDialog.pushButton.clicked.connect print_filename
	testDialog.toolButton.clicked.connect get_filename
	testDialog.show()
The '...' button updates the internal filename var with the picked file and the other button prints it in listener. I've made the testDialog global so that it can be easily closed if it already exists.
Message 5 of 24
Swordslayer
Creating the UI directly without the help of a .ui file seems to work rather nice as well:
	local QtWidgets = python.import "PySide2.QtWidgets"
	global testDialog = QtWidgets.QDialog(GetQMaxMainWindow())
	testDialog.setWindowTitle "Pyside Qt Window"
	local dialog_layout = QtWidgets.QVBoxLayout()
	local label = QtWidgets.QLabel "Click button to create a cylinder in the scene"
	dialog_layout.addWidget label
	fn make_cylinder = with undo on Cylinder isSelected:on
	local cylinder_btn = QtWidgets.QPushButton "Cylinder"
	cylinder_btn.clicked.connect make_cylinder
	dialog_layout.addWidget cylinder_btn
	testDialog.setLayout dialog_layout
	testDialog.show()
Message 6 of 24
Swordslayer
It's kinda fun to play with, that's for sure.
	if isProperty ::teapotRotator #close do teapotRotator.close()
	global teapotRotator = QtWidgets.QDialog(GetQMaxMainWindow())
	local layout = QtWidgets.QGridLayout()
	local dials = for i = 1 to 3 collect
		local btn = QtWidgets.QPushButton ("Zero " + #("X", "Y", "Z")[i] + " Rot")
		layout.addWidget btn 0 i
		btn.clicked.connect (execute ("(fn zeroRot = teapotRotator.zeroDials #{" + i as string + "})"))
		local dial = QtWidgets.QDial()
		layout.addWidget dial 1 i
		dial.setMaximum 360
		dial.setWrapping on
		dial.valueChanged.connect (execute ("(fn rot val = teapotRotator.setPotRot val " + i as string + ")"))
		dial.sliderPressed.connect (fn startHold = theHold.superBegin())
		dial.sliderReleased.connect (fn acceptHold = theHold.superAccept "Teapot Rotate")
		dial
	local togglePushButton = QtWidgets.QPushButton "Zero All"
	togglePushButton.clicked.connect (fn zeroAll = teapotRotator.zeroDials #{1..3})
	layout.addWidget togglePushButton 2 2
	delete $TeapotRot*
	local pot = Teapot prefix:"TeapotRot" isSelected:on
	py.setattr teapotRotator "setPotRot" (
		fn setRot val i =
			if isValidNode pot do with undo on pot[3][2][i].value = val
			redrawViews()
	py.setattr teapotRotator "zeroDials" (
		fn zeroDials idx = for i in idx do dials[i].setValue 0
	teapotRotator.setWindowTitle "Teapot Rotator"
	teapotRotator.setLayout layout
	teapotRotator.show()
Message 7 of 24
denisT.MaxDoctor
so soon you will get to lambdas 😉
Message 8 of 24
denisT.MaxDoctor
In any case, you are on the right track. The main idea behind using Qt is to create dynamic interfaces, which is a big problem for MXS.
Speaking of some of the issues above ...
I'm pretty sure we can find a workaround for most of the problems (like format, print), but that's not a solution. I need to be aware of all the limitations before starting any big project. In this case, I just want to first understand why the MXS format (print) is not working. Is this a main thread or basic output stream problem? Are they different for mxs and python, Qt(PySide2)? How could this happen?
Another one...
Attempting to UNDO a connected function may result in MAX failure if the function has not been run undoable.
Message 9 of 24
Swordslayer
Okay, that's kinda ugly, would you prefer this from the point of 'nice to read' code? 🙂
local partial = (python.import "functools").partial
fn zeroRot arg = teapotRotator.zeroDials #{arg}
btn.clicked.connect(partial zeroRot i)
Message 10 of 24
Swordslayer
Another one...
I'd expect the possible problems are the same as if you were usin pymxs from python i.e. this would apply (scroll down to MAXScript Undo and Redo and Printing to the Listener).
Message 11 of 24
denisT.MaxDoctor
before I start a serious project with MXS - Qt, I will test the entire pipeline ... as far as possible, I will keep you friends informed and updated
Message 12 of 24
Swordslayer
Sounds great, can't wait to see what you find. If there's anyone who could shed more light on this, it'd probably be @eric.brosseau or @attilaszabo (though with the next version release geting nearer and nearer, I imagine they're pretty busy).
Message 13 of 24
denisT.MaxDoctor
I have quite a lot of experience with Qt (Maya) user interfaces. As my experience shows, serious tools cannot be created without events. Connections are usually not enough. My guess is that Qt events can be a problem in MXS because additional Qt coding (override, extend) is always required.
Message 14 of 24
Swordslayer
Hmmm, did I miss something or can't you just a) replace the default event with a custom one, b) store the original if you want to extend it?
	testDialog.mousePressEvent = fn mousePressEvent evnt = py.print (py.str.format "dialog click at {}" (evnt.pos()))
	testDialog.setFixedSize 250 250
	local button = QtWidgets.QPushButton "Button" parent:testDialog
	button.clicked.connect (fn _ = py.print "original click")
	local origEvnt = button.mousePressEvent
	button.mousePressEvent = fn __ evnt = (py.print "extended click"; origEvnt evnt)
	testDialog.show()
Message 15 of 24
denisT.MaxDoctor
I don't like mixing code with different languages in one project. This is why I don't like using .NET in combination with MXS. And I don't use this combination lately, although in the past I have done many projects with mix of MXS and C#.
I usually make the whole interface in MXS and C++ now.
So it's okay for me to use the MXS python interface with access to Qt, but I don't want to do additional coding in Python and then use extended or custom modules.
Message 16 of 24
denisT.MaxDoctor
Oh. I didn't make myself clear. I mean a situation where a class (object) doesn't have a specific event and you need to add it.
Qt also has a very interesting mechanism called eventFilter that I may miss.
... looked just now ... hmm ... like you can write event filters in MXS.
It's a pity, but now there is no time to try.
Message 17 of 24
denist.dts
defining them as:
we can wrap connection function with undo and other contexts like:
fn runfn undotext fun =
	undo undotext on
		fun()
fn deleteAll = (delete objects)
ww.Button_1.clicked.connect (partial runfn "Select None" clearSelection)
ww.Button_2.clicked.connect (partial runfn "Delete All" deleteAll)
Message 18 of 24
denist.dts
can we pack with partial optional arguments as well:
fn deleteNodesByClass class: =
	delete (for node in objects where iskindof node class collect node)
-- partial this: ???
deleteNodesByClass class:point
Message 19 of 24
How would I trigger close events using this method ?
Can't find a way...
Thanks !
Message 20 of 24
denisT.MaxDoctor
Can't find a way...
Please open a new topic with a full and clear title and question.
