Maxcsript Bug?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
My script currently applies a unwrapUVW modifier to an object and then flattens the map by polygon angle.
modPanel.setCurrentObject currentObject unwrapModifier = UVWunwrap () unwrapModifier.setApplyToWholeObject true addmodifier currentObject (unwrapModifier) currentObject.modifiers[#unwrap_uvw].flattenMap 45.0 #() 0.001 true 0 true true
The modifier is added correctly, however the flatten map part of the script doesn't seem to work if I just run it from a newly opened session of max.
But if i either select all the faces and flatten the map using the UV editor or apply the modifier and unwrap manually to any object, the script will run fine afterwards on any object.
It seems like it flatten map operation doesn't know what to do until I do it at least once manually.
Does anyone have any insight into why this might be happening? I've been struggling with it for days now.
