Make each poly element planar on z axis for multiple objects
patrickwongWA5QB
Observer Observer
Message 1 of 10
patrickwongWA5QB
Observer
Observer
I am currently working on a script that can help me make every poly element of a particular materialID planar locally in a poly object that will loop over multiple objects. I have this so far:
PolyObj = selection as Array
for obj in PolyObj do
	poSetFaceSelection = polyop.setFaceSelection
	-- select material ID 1
	$.selectByMaterial 1
	-- sets the selected face indices as an array
	flattenFaces = getFaceSelection $ as Array
	print flattenfaces
	-- function to clear selection
	clearPolySel = polyop.SetFaceSelection $ #none
	-- cycles through the list of faces to flatten then makes planar in Z
	for i = 1 to flattenFaces.count do
		clearPolySel
		poSetFaceSelection $ flattenFaces[i]
		$.MakePlanarIn #Z selLevel:#Face flag:1
currently the script in the body of the main for loop works when applied to a single object:
	print flattenfaces
		clearPolySel
I am currently trying to work out how to get it to work when having multiple objects.
what it should do is make elements that arent flat like this:
making it flat but still keeping the averaged height of the element:
any help regarding this would be much appreciated, thanks!
Replies (9)
Message 2 of 10
istan
I'd say using the "$" in your code is not the right approach..
Message 3 of 10
denisT.MaxDoctor
... making it flat but still keeping the averaged height of the element
I'm guessing what you're asking is "how to make a face element z-planar about its bounding box center"
fn getPolyFacesByMatID obj id:1 =
	faces = #{}
	for f=1 to obj.numfaces where (id == polyop.getFaceMatID obj f) do append faces f
	faces
fn collectPolyFaceElements obj faces: =
	if faces == unsupplied or faces == #all then
		faces = #{1..(polyop.getnumfaces obj)}
	else if faces == #selected do
		faces = obj.selectedfaces as bitarray
	elems = #()
	for f in faces where faces[f] do
		ff = polyop.getelementsusingface obj f
		append elems ff
		faces -= ff
	elems
fn makePolyFacesPlanarZ obj faces =
	vv = polyop.getVertsUsingFace obj faces
	center = [0,0,0]
	pos = for v in vv collect
		p = polyop.getvert obj v
		center += p
		p
	center /= vv.numberset
	k = 0
	for v in vv do
		p = pos[k += 1]
		p.z = center.z
		polyop.setvert obj v p
	pos
obj = selection[1]
faces = getPolyFacesByMatID obj
elems = collectPolyFaceElements obj faces:faces
for faces in elems do makePolyFacesPlanarZ obj faces
update obj
now we can do it for multiple selection ...
mapped fn planarPolyFacesByID obj id:1 = if iskindof obj Editable_Poly do
	faces = getPolyFacesByMatID obj id:1
	--format "% >> %\n" obj elems
	update obj
planarPolyFacesByID objects id:1
--planarPolyFacesByID selection
Message 4 of 10
denisT.MaxDoctor
some additional conditions are possible... for example, what if we want to make faces planar in the object coordinate space? well... we can do it too, but it will be another subject.
Message 5 of 10
denisT.MaxDoctor
Can we use editable_poly's built-in MakePlanarIn method? Yes, we can... but we still have to find the elements, specify the sublevel, and select our faces (or apply a custom flag). Usually, when we modify a selection for our needs, it's a good practice to revert the original selection back after the operation. That's why I prefer to use my own planar method to make things more manageable and without having to change the current face selection.
Message 6 of 10
patrickwongWA5QB
Observer
Observer
Thank you very much for the detailed reply! how should i be using this? i tried just pasting all your code into a new maxscript and ran it and nothing happens to the object. Thanks!
Message 7 of 10
denisT.MaxDoctor
run all my code, select one or more poly objects, and run:
planarPolyFacesByID selection id:1
Message 8 of 10
patrickwongWA5QB
Observer
Observer
ive pasted everything like this:
	faces = #{}
	faces
	elems = #()
		append elems ff
		faces -= ff
	elems
	center = [0,0,0]
		center += p
		p
	k = 0
	for v in vv do
		p = pos[k += 1]
		p.z = center.z
	pos
obj = selection[1]
update obj
	update obj
and then when i press Ctrl+E to run it i get this:
getPolyFacesByMatID()
collectPolyFaceElements()
makePolyFacesPlanarZ()
planarPolyFacesByID()
-- Error occurred in anonymous codeblock; filename: ; position: 1317; line: 67
-- Argument count error: planarPolyFacesByID wanted 1, got 4
-- MAXScript callstack:
--	thread data: threadID:29428
--	[stack level: 0]
--	In planarPolyFacesByID(); filename: ; position: 1318; line: 67
--		Parameters:
--			obj: $objects
--			id: 1
--		Locals:
--			elems: undefined
--			faces: undefined
--			obj: $Editable_Spline:Maproom_Satellite+Terrain @ [0.000000,0.000000,0.000000]
--			id: 1
--		Externals:
--			collectPolyFaceElements: Global:collectPolyFaceElements : collectPolyFaceElements()
--			getPolyFacesByMatID: Global:getPolyFacesByMatID : getPolyFacesByMatID()
--			owner: undefined
--	[stack level: 1]
--	called from top-level
OK
sorry about the noob question but im very new to maxscripting. Thanks!
Message 9 of 10
denisT.MaxDoctor
try(destroydialog PlanarFacesRol) catch()
rollout PlanarFacesRol "Planar with denisT" width:191
		faces = #{}
		faces
		elems = #()
			append elems ff
			faces -= ff
		elems
	fn makePolyFacesPlanar obj faces axis:3 =
		center = [0,0,0]
			center += p
			p
		k = 0
		for v in vv do
			p = pos[k += 1]
			if iskindof axis Number do p[axis] = center[axis]
		update obj
		pos
	group "Poly Objects: "
		radiobuttons nodes_list_rb labels:#("All", "Selected") columns:1 align:#left offset:[20,0]
	group "Faces: "
		radiobuttons faces_list_rb labels:#("All", "Selected", "By Material ID") columns:1  align:#left offset:[20,0]
		spinner matid_sp range:[1,255,1] type:#integer fieldwidth:42 align:#right offset:[4,-20] enabled:(faces_list_rb.state == 3)
	group ""
		radiobuttons planar_axis_rb "Axis: " labels:#("X", "Y", "Z") columns:3 default:3 align:#left offset:[0,-6] offsets:#([20,0],[10,0],[0,0])
		checkbox by_elements_cb "By Face Elements" checked:on offset:[0,4]
		button make_planar_bt "Make Faces Planar" width:172 align:#left offset:[-4,2]
	on faces_list_rb changed state do
		matid_sp.enabled = (state == 3)
	on make_planar_bt pressed do undo "Make Faces Planar" on
		nodes = case nodes_list_rb.state of
			1: objects
			2: selection
	  default: selection
		for node in nodes where iskindof node Editable_Poly do
			faces = case faces_list_rb.state of
				1: #{1..node.numfaces}
				2: node.selectedfaces as bitarray
				3: getPolyFacesByMatID node id:matid_sp.value
			elems = if by_elements_cb.state then collectPolyFaceElements node faces:faces else #(faces)
			for faces in elems do makePolyFacesPlanar node faces axis:planar_axis_rb.state
	on PlanarFacesRol open do
createdialog PlanarFacesRol
Learn MaxScript! Helps a lot!!!
Message 10 of 10
patrickwongWA5QB
Observer
Observer
This is wonderful, thank you very much for your help! Will learn more!
