nodeLocalBoundingBox gives different result in max2020 and max2022
miauuuu
miauuuu
Hi!
Here is the test scene - a teapot, at [0,0,0] and rotated 45 deg on its Y axis.
When I use
nodeLocalBoundingBox selection[1]
the results are:
max2020:   #([-14.11,-13.303,14.11], [30.9627,13.303,-1.33177])
max2022:   #([-14.11,-13.303,-16.1472], [30.9627,13.303,28.9254]) -> The same scene, opened in 3ds max 2022
The Z values are different:
max2020          max2022
14.11                    -16.1472
-1.33177              28.9254
When I use:
(nodeGetBoundingBox selection[1] selection[1].transform)[1] * selection[1].transform
the results are:
max2020:   [-14.11,-13.303,14.11] -> match the nodeLocalBoundingBox value
max2022:   [-14.11,-13.303,14.11] -> does not match the nodeLocalBoundingBox value(Z component)
(nodeGetBoundingBox selection[1] selection[1].transform)[2] * selection[1].transform
the results are:
max2020:   [30.9627,13.303,-1.33176] -> match the nodeLocalBoundingBox value
max2022:   [30.9627,13.303,-1.33176] -> does not match the nodeLocalBoundingBox value in max2022, but does match the nodeLocalBoundingBox in max2020.
This difference between nax2020 and max2022 when nodeLocalBoundingBox  is used is a bug or a feature?
https://miauu-maxscript.com/
denisT.MaxDoctor
from the point of view of common sense, the nodeLocalBoundingBox has never worked correctly since its publishing... it is easy to see this if you look at the size of the resulting bounding box:
[30.9627,13.303,-1.33177] - [-14.11,-13.303,14.11] =
[45.0727,26.606,-15.4418]
so in +2022 in this sense the bug is fixed
PS. because of this, I used my own "get local bbox" method instead of built-in nodeLocalBoundingBox, which are surprisingly match now in 2022+ versions.
denisT.MaxDoctor
/*************** Version 2020 *************/
Value*
	nodeLocalBoundingBox_cf(Value** arg_list, int count)
	check_arg_count(nodeLocalBoundingBox, 1, count);
	INode* node = get_valid_node((MAXNode*)arg_list[0], nodeLocalBoundingBox);
	MAXScript_TLS* _tls = (MAXScript_TLS*)TlsGetValue(thread_locals_index);
	const ObjectState& os = node->EvalWorldState(MAXScript_time_tls());
	Object* ob = os.obj;
	if (ob)
		Box3 bbox;
		ob->GetDeformBBox(MAXScript_time_tls(), bbox, NULL, FALSE);
		Point3 pmin = bbox.Min();
		((MAXNode*)arg_list[0])->object_to_current_coordsys(pmin);
		Point3 pmax = bbox.Max();
		((MAXNode*)arg_list[0])->object_to_current_coordsys(pmax);
		one_typed_value_local_tls(Array* result);
		vl.result = new Array (2);
		vl.result->append(new Point3Value (pmin));
		vl.result->append(new Point3Value (pmax));
		return_value_tls(vl.result);
	return &undefined;
/*************** Version 2023 *************/
Value*
	// nodeLocalBoundingBox <node> asBox3:<bool>
	check_arg_count_with_keys(nodeLocalBoundingBox, 1, count);
	Value* tmp;
	BOOL asBox3 = bool_key_arg(asBox3, tmp, FALSE);
	if (ob)
		Box3 bbox;
		((MAXNode*)arg_list[0])->object_to_current_coordsys(bbox);
		if (asBox3)
			return_value_tls(new Box3Value(bbox));
	return &undefined;
there is a difference ....
miauuuu
Thank you, Denis!
Here are the values when (nodeGetBoundingBox selection[1] selection[1].transform)[2] is used:
max2020: [22.8356, 13.303, 20.9522]
max2022: [22.8356, 13.303, 20.9522]
They are the same. But this:
returns:
max2020: [30.9627,13.303,-1.33176]  == (nodeLocalBoundingBox selection[1])[2] -> [30.9627,13.303,-1.33177]
max2022: [30.9627,13.303,-1.33176]  != (nodeLocalBoundingBox selection[1])[2] -> [30.9627,13.303,28.9254]
Here is how the issue was found:
