illegal self-reference help please :)
Cgillblack
Cgillblack
ok so i want to write a little script so that if object A moves to far away from object B then object B will move closer which i thought would be simple so this is how i started.
a = $A.pos
b = $B.pos
if distance a b < 30 then
else
I havent got past this, if I put this into a position script controller then I get an error saying "illegal self-reference" which I think I understand, its trying to refer to its own position while also trying to change it hence confusion but I cant think of how else to do it.
any advice would be very helpfull.
Thank you 🙂
Steve_Curley
Circular dependencies can be a bit tricky.
Remove the script controller (assign a PositionXYZ controller).
Assign a script controller to an unused controller - Scale is a good one to use.
Create 2 variables MyPos and OtherPos
Select MyPos > Assign Controller > select the PositionXYZ controller of the same object (the one we're wrinting the script on).
Select OtherPos > Assign Controller > the PositionXYZ controller of the other object.
The script then becomes
if distance MyPos.value OtherPos.value >= 30 then
else
Remember to move the other object, not this one, and
You MUST leave the last line as the original scale value!!!
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Cgillblack
Thank you, got it working now 😄 but i have encountered another problem.
If i have autokey turned on then it keys every frame on the follow object can i make something "unkeyable"?
heres my code if anyones curious
a = $point001.pos
b = $point002.pos
d = distance a b
$point002.dir = a-b
if (distance a b) <= 20 then
$Circle001.wirecolor = green
else
$Circle001.wirecolor = red
$point002.pos = ($point002.pos + ($point002.dir*(d-20)))
if currenttime <= 0f then
$point002.pos =
else
thanks 😄
