How to write max script to make animation which a object rotates about another object with curved motion path
FelixP5NJM
FelixP5NJM
This is my code:
with animation on
    at time atFrame
	rotate $Top (AngleAxis rotateAngle [0,0,1])
	**in coordsys $Top about $Top.pos rotate $Module1 rotateAngle z_axis**
But it gives me a straight path. what max script should I write to make the path circular?
Thank you!
denisT.MaxDoctor
sounds obvious... create a path controller (path_constarint) for the position and a look_at controller for the rotation, where the target is the node we're rotating around
denisT.MaxDoctor
something like this:
delete objects
with redraw off
	trg = dummy name:#target boxsize:[10,10,10]
	src=point name:#source box:on axistripod:on cross:on size:20 wirecolor:orange
	sp = ellipse name:#path length:200 width:100 wirecolor:yellow
	converttosplineshape sp
	setKnotPoint sp 1 2 [0,100,30]
	setKnotPoint sp 1 3 [-50,0,50]
	setKnotPoint sp 1 4 [0,-120,20]
	updateshape sp
	path_control = path_constraint path:sp
	src.position.controller = path_control
	rot_control = lookat_constraint viewline_length_abs:off
	rot_control.appendTarget trg 1.0
	src.rotation.controller = rot_control
