How to write a progress bar in Max using python script?
I have written i python script and it works.
Now i want to add a function in my python script, to show a progress bar in 3ds Max.
Is there any inside API in 3ds Max to achieve Progress Bar like Tqdm but in Max UI instead?
Thanks 🙂
drew_avis
I would use the PySide2 / Qt progressbar widget.  Here's the "demoPyQWidget.py" example, I've added a progress bar and a button that randomly sets the progress value, just so you can see what it looks like.
	Demonstrates how to create a QWidget with PySide2 and attach it to the 3dsmax main window.
from PySide2 import QtCore
from PySide2 import QtWidgets
import pymxs
import random
def make_cylinder():
	cyl = pymxs.runtime.Cylinder(radius=10, height=30)
	pymxs.runtime.redrawViews()
	return
class PyMaxDialog(QtWidgets.QDialog):
	def __init__(self, parent=MaxPlus.GetQMaxMainWindow()):
		super(PyMaxDialog, self).__init__(parent)
		self.setWindowTitle('Pyside Qt Window')
		self.initUI()
	def setProgress(self):
		self.progressbar.setValue(random.randint(1,100))
	def initUI(self):
		main_layout = QtWidgets.QVBoxLayout()
		label = QtWidgets.QLabel("Click button to create a cylinder in the scene")
		main_layout.addWidget(label)
		cylinder_btn = QtWidgets.QPushButton("Cylinder")
		cylinder_btn.clicked.connect(make_cylinder)
		main_layout.addWidget(cylinder_btn)
		self.progressbar=QtWidgets.QProgressBar()
		main_layout.addWidget(self.progressbar)
		prog_btn = QtWidgets.QPushButton("Progress")
		prog_btn.clicked.connect(self.setProgress)
		main_layout.addWidget(prog_btn)
		self.setLayout(main_layout)
		self.resize(250, 100)
def main():
	w = PyMaxDialog()
	w.show()
if __name__ == '__main__':
	main()
Hope that helps,
Drew
Drew Avis
Content Experience Designer
Thx, it really works :)Smiley Embarassed
But the whole widget hangs and i can't see the moving until 100%, while the python script is running.
Can i get access to the Max original progress bar(in my py script) on the bottom of the UI like this. Maybe this will not be hang and i can see the bar moving ?
drew_avis
Hi, yes you can access that progress bar using pymxs.  Have a look at this MAXScript topic:
http://help.autodesk.com/view/3DSMAX/2020/ENU/?guid=GUID-5C069EAA-E2EB-4F7B-B6AC-DECD51121348
Simple example:
rt = pymxs.runtime
rt.progressStart('Doing something')
for i in range (1,1000):
	rt.progressUpdate(i/10)
rt.progressEnd()
Hope that helps,
Drew
Drew Avis
denisT.MaxDoctor
because you do something wrong. show your code and we will be able to say what you do wrong specifically.
Thank you very muchSmiley Happy, now i can get access the Status Bar of 3ds Max. Thanks again for your answer 🙂
This is how i use the progress bar:
	def initUI(self):
# to simplify my code structure, i name the function as doSomething()
def my-for-loop:
for i in range(1000):
doSomething(i)
# i set value by index
self.progressbar.setValue(100.0 * (1 + i) / 1000)
I want to show how the for-loop advancing, so i put a progress bar. But whenever the for-loop starts, 3ds Max hangs itself, and i can't see the bar moving until loop finish 😞
