I am trying to import rigging datas from my own software. Once I have created all the bones and the hierarchy, I try to add weights for each vertex of my model. However, the "AddWeights" method from ISkinImportData returns false each time I try to add weights on an extreme bone.
Here is how create the bones:
// itBone is an iterator on a map <size_t, myBoneStructure>
// node is the node corresponding to my model in 3dsMax
Modifier* skin = (Modifier*)CreateInstance(SClass_ID(OSM_CLASS_ID), SKIN_CLASSID);
ISkinImportData* skinInterface = (ISkinImportData*)skin->GetInterface(I_SKINIMPORTDATA);
GetCoreInterface12()->AddModifier(*node, *skin);
std::map<size_t, INode*> bonePerId; for (auto itBone = xstObj->skinningData_.GetSkinningBoneData()->Begin(); itBone != xstObj->skinningData_.GetSkinningBoneData()->End(); ++itBone) { Object* pBone = (Object*)ip->CreateInstance(GEOMOBJECT_CLASS_ID, BONE_OBJ_CLASSID); INode* boneNode = ip->CreateObjectNode(pBone); std::string boneName = "Bone_" + boost::lexical_cast<std::string>(mySkeletonIndex); boneName += boost::lexical_cast<std::string>(itBone->first); std::wstring wideBoneName = std::wstring(boneName.begin(), boneName.end()); const wchar_t* result = wideBoneName.c_str(); const MCHAR* nodeName(result); boneNode->SetName(nodeName); bonePerId[itBone->first] = boneNode; }
Here is how I create my hierarchy:
for (auto itBone = meshObj->skinningData_.GetSkinningBoneData()->Begin();
itBone != meshObj->skinningData_.GetSkinningBoneData()->End(); ++itBone)
const size_t &parentBoneId(itBone->first);
const SkinningBone &parentBone(itBone->second);
INode &parentMaxNode(*bonePerId[parentBoneId]);
const std::vector<size_t> &childIds = parentBone.GetChildIds();
// For each child
for (auto childIt(childIds.begin()); childIt != childIds.end(); ++childIt)
// Attach it to the parent
const size_t &childId(*childIt);
SkinningBone & childBone =
meshObj->skinningData_.GetSkinningBoneData()->GetSkinningBone(childId);
INode &childMaxNode(*bonePerId[childId]);
parentMaxNode.AttachChild(&childMaxNode);
// Position and rotate it
Point3 posDelta = childBone.GetBonePosition() - parentBone.GetBonePosition();
posDelta = msg->tsf_ * posDelta * 40;
const Point3 posDeltaMax(posDelta.x, posDelta.y, posDelta.z);
Matrix3 mat;
mat.SetTranslate(posDeltaMax);
childMaxNode.SetNodeTM(0, mat);
}And finally here is how I add the weights :
for (auto itWeights = weightsPerBonePerVertice.begin(); itWeights != weightsPerBonePerVertice.end(); ++itWeights)
Tab<INode*> tabNodes;
Tab<float> tabWeights;
int count = (int)itWeights->second.size();
tabNodes.SetCount(count);
tabWeights.SetCount(count);
size_t index = 0;
for (auto itBone = (itWeights->second).begin(); itBone != (itWeights->second).end(); ++itBone)
float weightForBone = (float)itBone->second;
tabNodes[index] = bonePerId[itBone->first];
tabWeights[index] = weightForBone;
index++;
bool addedWeights = skinInterface->AddWeights(node, (int)itWeights->first, tabNodes, tabWeights);
}Say my model is a tree with 5 bones, the 4th is the end of a branch and the 5th is the end of the trunk. Then, when AddWeights tries to add some weights on either of those two bones, the method returns false.
What did I do wrong ? Why does it returns false and refuses to add weights to those bones ?
Thank you !
