How to set Morpher by key name with script?
YASUSHI_EMOTO
YASUSHI_EMOTO
I am creating a script to set the value of Morpher.
If I write the following code, I can set all Morpher to 100.
mph=$.morpher
for i = 1 to 100 do (
 mph[i].value = 100
However, I do not want to set all values to 100.
I want to set the value of mouthOpen to 30, and the value of mouthSmile to 60, and so on.
And if I create the following code, there will be 100 loops each time, even though I have only set up 2 Morpheres.
I want to reduce the number of loops in order to create a faster code.
Is there anything I can do?
mph=$.morpher
  if "mouthOpen" == WM3_MC_GetName mph i then
   mph[i].value = 30
  if "mouthSmile " == WM3_MC_GetName mph i then
   mph[i].value = 60
10DSpace
@YASUSHI_EMOTO
The maxscript property,  WM3_MC_HasData provides a  way for you to only loop through morph channels which contain data.
So substituting the following conditional for loop for your current for loop should do what you are asking:
for i = 1 to 99 where (WM3_MC_HasData mph i == true) do
