i want push button from script
geme9876
geme9876
i want push that button from script
but i can't get button's hwnd
help
tagopinath
Try this script
maxOps.trajectoryMode = false (true - will set check Motion Paths button)
Regards
Gopi.
Swordslayer
It's Qt UI so you have to get the container hWnd and use that:
QtWidgets = python.import "PySide2.QtWidgets"
setCommandPanelTaskMode #motion
cpHWnd = ((dotNetClass "Autodesk.Max.GlobalInterface").Instance.UtilGetCoreInterface16()).CommandPanelRollup.Hwnd
cpRoot = (windows.getHWndData cpHWnd)[7]
motionHWnd = (windows.getChildrenHWnd cpRoot)[3][1]
motionWidget = QtWidgets.QWidget.find motionHWnd
for w in motionWidget.children() as array
	where w.__class__ == QtWidgets.QPushButton and w.text() == "Parameters" do
		w.click()
geme9876
thank you for reply !! very helpful
geme9876
that's what i find.
but I'm  using max 2019 version, there is a some issue when getting hwnd function ( return float value )
So I solved the problem by getting all the QT widgets and iterating them.
thank you!!!
Swordslayer
Whatever works 🙂 In pre-2018.2 or so CommandPanelRollup.Hwnd was broken anyway (always returned zero) so you had to do a lot of gymnastics to get the right handle (different ways when it's undocked, if you get it by the string you have to cover localized versions etc).
