How to scripting for Antialiasing screen shot of the viewport?
Waseem_Dabbas
Waseem_Dabbas
I posted this question in the forum before, but I may not be able to explain my problem very well,
Check this video out
(view in My Videos)
The one on the left has been generated by the grab viewport tool, you can see how's it's clear and fine, but the one on the right has been generated by a script called "multicamerapreview" which has a lot of aliasing, I need to use this script because it can grab many cameras in the scene at once, but It doesn't have the option to control the quality of the image (Antialiasing).
 Is it possible to control this feature? Can someone help me add this option?
denisT.MaxDoctor
is it not easier to change the blinds in the background? 🤔
Waseem_Dabbas
If that's the only problem, I would change it.
Actually, I'm working on about 3 minutes interior file containing many other cameras, I just share these 5 seconds as a sample, and I'm trying to find a solution not only for this project but for future work. 🙏🏻
denisT.MaxDoctor
As I understand it, you want to use multiple cameras to shoot your video preview. Let's simplify things answering these questions:
1. How maximum cameras does it make sense to use to make one video?
2. What type (class) of cameras do you use?
3. What camera parameters do you animate for video?
Waseem_Dabbas
1. I have 9 cameras ( but it can be maximum to lets say 15)
2. Im using Vray Physical Camera.
3. Position and Rotation.
denisT.MaxDoctor
What parameters might be different for cameras which affect rendering settings? (FOV, Clipping, Color, Texture, etc.)
Waseem_Dabbas
Nothing from the mentioned will be changed during the render, the only change is the location (position x,y,z) or the camera and the rotation angle.
