Announcements
Toggle selection on and off with Show/End result
keith_brown
keith_brown
I've put together a simple script that (in this case) toggles a mesh smooth modifier and hides the edges.
	showEndResult = not showEndResult
	actionMan.executeAction 0 "369"
When the showEndResult is true, however, the vertices are still there. Is there a way to hide these when it's true and enable the latest selection again when showEndResult is false?
Script is binded to my TAB key when toggling:
denisT.MaxDoctor
... because the sub-object level still set to 1 (#vertices in your case). You can change subobjectlevel to 0:
subobjectlevel = 0
but storing and restoring the previous level for the current object you have to do yourself. There is no built-in mechanism for this.
keith_brown
Yes I tried making some if, else statements but as you say.
I can't store a variable that holds the latest subobjectlevel. If I set it to 0 it will be 0 further on.
