How to position multiple copied groups?
Hi all,
firstly thanks for looking this one over.
I have had a little experience with scripting and programming in the past but generally just learn what I need for the task at hand, then forget it all a week later 😞
What I am attempting to achieve is to get the width, height and length of a group, then duplicate that group multiple times in all axis and position each group next to, along, and on top of the previous duplication.
I'm pretty sure that I am close with this (It works for a none grouped object) but I keep getting an error (-- Runtime error: Not a keyword argument: #pos) at the "pos: [poz_x, pos_y, pos_z]" section of my script (Right at the bottom).
Can anyone help me with this please?
global FindGroupHead
	fn FindGroupHead obj =
		 if ((isGroupHead obj)AND(not (isGroupMember obj))) then
			return obj
		 else
		if (isGroupMember obj) then
			FindGroupHead (obj.parent)
		else
				return undefined)
on PickFillMesh picked sel do
local SelectedGroupHead = (FindGroupHead sel)
		---------- Get Selected Mesh Dimensions
		FillMeshWidth = (SelectedGroupHead.max - SelectedGroupHead.min).x
		FillMeshLength = (SelectedGroupHead.max - SelectedGroupHead.min).y
		FillMeshHeight = (SelectedGroupHead.max - SelectedGroupHead.min).z
		---------- Clone Selected Mesh and Position
		for HeightAmount = 1 to StackHeight.value do
			for LenghtAmount = 1 to StackLength.value do
				for WidthAmount = 1 to StackWidth.value do
					pos_z = ((HeightAmount-1) * FillMeshHeight)
					pos_y = ((LenghtAmount-1) * FillMeshLength)
					pos_x = ((WidthAmount-1) * FillMeshWidth)
					maxOps.cloneNodes SelectedGroupHead cloneType:#instance --error here>>>-- pos:[pos_x, pos_y, pos_z]
miauuuu
Calculate pos_x, pos_y, pos_z as offset, not as position, and use
maxOps.CloneNodes selectedGroupHead cloneType:#instance offset:[pos_x, pos_y, pos_z]
https://miauu-maxscript.com/
Thanks miauuuu, that's done the trick, the only issue now is that it is sort of making the first duplicate in the same position of the selected group, let me try and elaborate.
I have a group in the scene, in my UI I have 3 spinners (Length, Width and Height) and a pick button. If I leave my spinners at a value of 1. when I pick the group to duplicate it duplicates on the spot, this is correct behaviour but not what I want.
I need it to either delete the original group or ignore the first duplication. Any ideas?
miauuuu
Try this:
			return obj
		 else
		else
				return undefined)
	--	"credits to denisT"
	fn GetGeometryGroupMembers node = if isgrouphead node do
		for node in (join #() node) where iskindof node geometryclass and canconvertto node editable_mesh collect node
	fn isGroupHeadMember head node act:off =
		while isvalidnode node and isgroupmember node and not (act = (node.parent == head)) do node = node.parent
		act
	fn getAllGroupMembers head = if isgrouphead head do
		for node in (join #() head) where isGroupHeadMember head node collect node
		delete (getAllGroupMembers SelectedGroupHead)
		--	"if group head is not deleted"
		--	delete SelectedGroupHead
Works like a charm, thank you for all the help.
