Announcements
Bounding points
Bounding points
Bounding points
I want to create a script that will do the following:
It will be started on a model (one editable poly) and will create a simpler object, that should be a collider for the same model. I can optimize the model, "ruin" the original model, I just want a simple collider. (Adding pictures to show the situation)
If you have a different idea of how to do this (The goal is to get a convex bounding Poly so I can use it as a collider) I would love to hear them
Swordslayer
If you want just a convex hull, there's a command for that. You wanted a poly so here you go:
convertToPoly (nvpx.CreateBoundingShapeConvex $ 1e4 .0 1)
This is not exactly what I thought, but it is fantastic! Thank you so much!
