How to ITab<> class with .NET c#
sharfym
sharfym
ITab<IPoint3> pnts = Global.Tab.Create<IPoint3>();
ITab<IntPtr> adr = Global.Tab.Create<IntPtr>();
Are there any code snippets available that show usage of  ITab<> class and its functions with max .net.
thanks
An ITab<T> is really just a List<T>, without actually implementing the IList, ICollection, etc. interfaces.
I wrote a little extension method to convert ITab<T> to an IEnumerable to easily iterate through the list:
        public static IEnumerable<T> ToIEnumerable<T>(this ITab<T> itab)
            if (itab == null)
                yield break;
            for (int i = 0; i < itab.Count; i++)
                yield return itab[i];
If you're asking for an example of where you'd use an ITab, my most common case is the result of running MaxScript from C# - you'll often want to return an ITab<> of data. Here's one that's 100% in C# though:
ITab<IMtlBase> materialsLib = GlobalInterface.Instance.COREInterface15.SceneMtls;
foreach (var materialBase in materialsLib.ToIEnumerable())
[Deleted]
