how to get "enable in renderer" option in C++
xiesansi
xiesansi
I was trying to get "Enable In Renderer" value in C++.
I tried
node->Renderable()
but it returns 1 all the time whether I check this box or not.
Should I use some other method?
Thank you!
tagopinath
If you are ok to use maxscript inside your C++ code, then you can try this.
$.baseobject.renderable
The result bool value will give you the status.
Gopinath.
Swordslayer
xiesansi
it works, actually, I made it by
ObjectState os = node->EvalWorldState(0);
ShapeObject* shape = (ShapeObject*)os.obj;
auto renderable = shape->GetRenderable();
