How to enable "Always show motion path" using MAXScript?
FelixP5NJM
FelixP5NJM
denisT.MaxDoctor
it's the same as setTrajectoryOn on the selected object... it doesn't automatically redraw the checkbox, so you're worried that you can force an update like this:
select $
FelixP5NJM
Thank you!
Do you know how to set "Motion Paths" > "Display" > "Path Coloring" using MAXScript?
denisT.MaxDoctor
maxOps.trajectoryPathGradation: enum : Read|Write
trajectoryPathGradation enums: {#speed|#wirecolor|#uicolor|#none}
FelixP5NJM
thank you so much.
many times, it is so hard to find a function in documentation without knowing its name😞
