Detach script with c ++
anycganycgJ8A6A
Message 1 of 45
anycganycgJ8A6A
hi
Nice to meet you
I have a problem
I have a 5000 object
That is attached..
I would like to detach with elements
I tested many detahel script
But all is failed or max freezz problem
So i found this link
C++ detach script
https://forums.cgsociety.org/t/c-detach-by-elements/1707338
If i use c++ , can i detach my objects
I dont know c++
Uf that is possible , can you help that ?
Replies (44)
Message 2 of 45
denisT.MaxDoctor
Since I am the actual author of this code, it will probably be easier for me to answer you.
If you don't know c++, then this code won't help you. It's impossible to just take it and somehow execute it in 3DS MAX.
Only the MaxScript solution will suit you and nothing else. If you couldn't find a working script, it doesn't mean that it doesn't exist. You just haven't come across any good ones.
The easiest way to get a working solution is to post an example of a max scene (MAX 2020 version), and clearly tell which object and how should be detached by element...
Actually, there are two technical problems here (not one):
1. find all the necessary elements
2. detach them
So, we need to take a look first
Message 3 of 45
anycganycgJ8A6A
really thank you for reply
https://drive.google.com/file/d/1eJQo2kvwSnBHH94Z6d2WtJbIgfebCic7/view?usp=sharing
that is attached object
i am sorry
pls can you detach test ?
i would like to know detach speed with c++ script
my pupose is element detach.
thank you again ~
Message 4 of 45
denisT.MaxDoctor
It should be noted that the task is not easy for c++ either.
Just so you know, your example does not have 5000 elements as you said, but 50000(!)... and that's a big difference.
So far, I can't solve this problem with a pure maxscript, but it's a challenge for me, and I'm interested in solving this problem anyway
Message 5 of 45
anycganycgJ8A6A
Really really thank you for your effort
I wish you can do that ~
At any way thank you
Message 6 of 45
denisT.MaxDoctor
how fast does it have to be to make you happy? 😉
Message 7 of 45
anycganycgJ8A6A
Thank you for your kindness
As fast as possbile.
5 seond is very happy
10 second is very happy also
Really Sorry for rude request :
Message 8 of 45
denisT.MaxDoctor
Ha ha ha... you're naive. While we can talk about 3-5 minutes
Message 9 of 45
anycganycgJ8A6A
i adore you
I always think of your word as the word of God
Even if I become a stone, I will wait for your answer
Message 10 of 45
denisT.MaxDoctor
I'm just wondering... why attach all the objects to one mesh first and then detach them piece by piece again?
It turns out 50,000 objects ... it is simply impossible to work with such a number!
you imagine detaching all in 3-5 seconds...
let's do a simple experiment, just try to create 50,000 comparable by size box objects:
	delete objects
	t0 = timestamp()
	h0 = heapfree
	bb = for k=1 to 50000 collect
		b = box lengthsegs:2 widthsegs:2 heightsegs:2 pos:(random -[1000,1000,1000] [1000,1000,1000])
		converttomesh b
	format "count:% time:% heap:%\n" bb.count (timestamp() - t0) (h0 - heapfree)
how long does it take on your machine?
Message 11 of 45
anycganycgJ8A6A
really thank you for reply again
first of all, i tested
count:50000 time:17770 heap:49620672L
Please understand my poor English skills
Here's why it's made with one mesh:
I often get attached large objects from clients.
So I have to separate for mapping.
So this time
I have a curiosity that I want to solve
My curiosity won't stop
Message 12 of 45
anycganycgJ8A6A
second : count:50000 time:11445 heap:49893368L
third : count:50000 time:11601 heap:49891960L
denist , i have a question
without opening max program , Is it impossible to run a script from the command line?
Message 13 of 45
denisT.MaxDoctor
In this case, you do not need to detach all the parts. Detach only those you need to work on at the moment and reattach them when the job is done.
It also makes sense to specifically do the mapping for only certain parts, and copy the mapping from them to the same or similar ones. This will save you a lot of time.
Message 14 of 45
denisT.MaxDoctor
in general, consider that it is impossible. Expect MAX must be opened to run tools...
The "hidden UI" option (launching MAX without a UI) is designed and used almost exclusively for rendering purposes. Running MAX with command line is not an area in which my expert opinion means something. Surely there are more experienced people in this topic
Message 15 of 45
anycganycgJ8A6A
Really Thank you for good advice
I have many style in my work
1. Detach all , and replace that
2. Other complex attached scene , extract model
Etc...
Files from clients have a lot of different styles.
I felt it was convenient to work after just detaching the whole thing.
Message 16 of 45
denisT.MaxDoctor
try this:
try(destroydialog TakeApartRol) catch()
rollout TakeApartRol "Take Apart" width:191
	fn getAllMeshElements node faces: detach:on pb: ni: gi: ti: mi: gc_count:0 =
		prefix = node.name + "_"
		local tmesh = snapshotasmesh node
		--local amesh = copy tmesh
		local num_groups = 0
		local num_elements = 0
		local elements = #()
		local _detachfaces = meshop.detachfaces
		local _deletefaces = meshop.deletefaces
		local t0 = timestamp()
		local numverts = tmesh.numverts
		local numfaces = tmesh.numfaces
		local allfaces = #{1..numfaces}
		local verts = for v = 1 to numverts collect #()
		for j in allfaces do
			f = getface tmesh j
			for k = 1 to 3 do append verts[f[k]] j
		out = false
		local element = #()
		if faces == unsupplied do faces = allfaces
		for i in faces while not keyboard.escPressed do
			element = #(i)
			for j in element where faces[j] do
				faces[j] = false
				f = getface tmesh j
				for k = 1 to 3 where verts[f[k]] != undefined do
					join element verts[f[k]]
					verts[f[k]] = undefined
			if detach then
				join elements element
			else
				append elements (element as bitarray)
			num_elements += 1
			if pb != undefined do pb.value = mod (num_elements/10.0) 100
			if ni != undefined do ni.text = num_elements as string
			if gc_count and (mod num_elements gc_count == 0 or i == numfaces) do
				--gc light:on
				if detach do
					m = _detachfaces tmesh elements delete:false asmesh:true
					name = uniquename prefix
					n = editable_mesh name:name parent:node
					n.mesh = m
					elements = #()
				num_groups += 1
				if gi != undefined do gi.text = num_groups as string
				if ti != undefined do ti.text = ((timestamp() - t0) / 1000) as string
				local val = int (100.0 * heapFree / heapSize + 0.5)
				if mi != undefined do mi.text = val as string
				windows.processPostedMessages()
			out = true
		num_elements
		elements
	label facetype_lb "Face Targets: " align:#right offset:[0,4] across:2
	radiobuttons facetype_rb labels:#("All", "Selected") columns:1 align:#left offset:[0,3]
	label bycount_lb "Group By Count: " align:#right offset:[0,4] across:2
	radiobuttons bycount_rb labels:#("1", "10", "100", "1000", "10000") default:1 columns:1 align:#left offset:[0,3]
	checkbox detach_ch "Detach" align:#left offset:[0,0] --across:2
	button mxs_detach_bt "MXS Process" width:172 align:#left offset:[-4,2]
	progressbar progress_pb color:orange width:172 height:10 align:#center offset:[0,0]
	group "Statistics: "
		label number_lb "All Elements" align:#left offset:[8,0] across:3
		label info_01 "0" align:#right offset:[40,0]
		label data_01 "" width:20 align:#right offset:[8,0]
		label groups_lb "Groups By Count" align:#left offset:[8,0] across:3
		label info_02 "0" align:#right offset:[40,0]
		label data_02 "" width:20 align:#right offset:[8,0]
		label time_lb "Time" align:#left offset:[8,0] across:3
		label info_03 "0" align:#right offset:[40,0]
		label data_03 "s" width:20 align:#right offset:[8,0]
		label heap_lb "Memory" align:#left offset:[8,0] across:3
		label info_04 "0" align:#right offset:[40,0]
		label data_04 "%" width:20 align:#right offset:[8,0]
	group "Settings and Debug: "
		checkbox debugh_ch "Debug" align:#left offset:[0,4] across:2
		checkbox gclight_ch " GC Light" align:#left offset:[20,4]
		button gc_bt "Garbage Collection" width:172 align:#left offset:[-4,2]
	fn memoryDisplay =
		local val = 100.0*heapFree/heapSize + 0.5
		info_04.text = (int val) as string
	on gc_bt pressed do
		gc light:gclight_ch.state
		memoryDisplay()
		completeRedraw()
	local num
	local t0, t1
	local h0, h1
	on mxs_detach_bt pressed do undo "Detach" off, with redraw off
		node = selection[1]
		if iskindof node GeometryClass do
			gc light:on
			memoryDisplay()
			t0 = timestamp()
			h0 = heapfree
			mesh = gettempmesh node
			faces = if facetype_rb.state == 1 then #{1..mesh.numfaces} else (mesh.selectedfaces as bitarray)
			count = #(1,10,100,1000,10000)[bycount_rb.state]
			global _ee = GetAllMeshElements node faces:faces detach:detach_ch.state \
				pb:progress_pb ni:info_01 gi:info_02 ti:info_03 mi:info_04 gc_count:count
			t1 = timestamp()
			h1 = heapfree
			format "count:% time:% heap:%\n" _ee.count (t1 - t0) (h0 - h1)
	on TakeApartRol open do
		gc light:on
		memoryDisplay()
createdialog TakeApartRol
Message 17 of 45
denisT.MaxDoctor
you have a pretty fast machine, so the script might not be too slow for you
Message 18 of 45
anycganycgJ8A6A
I fell asleep and woke up .
You gave me something big like Santa Claus.
thank you thank you thank you
I'll test it tomorrow after I get some sleep.
thank you so much.
Message 19 of 45
Serejah
Removing frequent stats updates and unrolling 1..3 loops made it noticebly faster from 5.856sec to 4.176sec. But I'm not sure if it depends on a test scene. I used a few dozens of teapots collapsed together.
Message 20 of 45
denisT.MaxDoctor
I'm pretty sure you're right... there are a few traces, mostly for debugging and analysis, and they should be removed in the final version.
