Customize Right Click Menu on Material Node
mitchell.lotierzoJ5X6W
Message 1 of 9
Anyone know if you can customize this menu detailed here? The menu doesn't show up in the 'Customize User Interface' dialog and I can't seem to find an entry for it using 'menuMan' in MAXScript.
Any help would be greatly appreciated!
Replies (8)
Message 2 of 9
denisT.MaxDoctor
fn dumpItem item tab:"" out: =
	t = item.gettitle()
	format (tab + "%\n") t to:out
	if not i.getIsSeparator() do
		s = i.getSubMenu()
		if s != undefined do
			dumpMenu s tab:(tab + "\t") out:out
fn dumpMenu menu tab:"" out: =
	t = menu.gettitle()
	for k=1 to menu.numitems() do
		i = menu.getitem k
		dumpItem i tab:(tab + "\t") out:out
fn menuInspector menu: tab:"" out: =
	for k=1 to menuMan.nummenus() do
		m = menuMan.getmenu k
		dumpMenu m tab:(tab + "\t") out:out
out = newScript()
menuInspector out:out
try this "inspector", uncomment the comments, run, and then use a simple search...
Unfortunately for you, the menu you are looking for goes through a different system (not the Menu Manager) and cannot be extended with pure MXS. The Slate Material Editor has its own set of RC menus.
Message 3 of 9
@denisT.MaxDoctor Thanks for this! So, do you know how I would go about extending those menus? Should I be looking into the C++ SDK or?
Message 4 of 9
denisT.MaxDoctor
Since you don't have the resources for the Slate Editor, the only chance I see is to catch the popup menu with a dialog monitor and add items on the fly. You can do it with C++  or C# (which might be easier). The MAX SDK must be used to call the methods you wish to add. Adding "custom menus" does not require the SDK.
Message 5 of 9
denisT.MaxDoctor
just curious what methods you want to add to those menus?
Message 6 of 9
Serejah
@mitchell.lotierzoJ5X6W  написал (-а):
you can use this thread as a starting point
https://forums.cgsociety.org/t/can-mxs-add-custom-menus-to-eg-maxscript-editor/2056944
As you can see it is possible to add, but it is a pain to continuously monitor that some sme context menu just opened and the hardest part is to monitor if user actually clicked some of your custom menu items
Message 7 of 9
denisT.MaxDoctor
how is about to add a new (custom) item to the specified submenu😉
Message 8 of 9
Serejah
@denisT.MaxDoctor  написал (-а):
hmm.. I just tried that and each time submenu pops up it adds another item, so the submenu stays the same for currently opened parent-menu. So we need to check whether custom items were already added to a submenu with such a handle.
I didn't play much with menu customization, but can't see any good window message to catch up click/mouseup/keyup event on particular item
Do you have any ideas, Denis?
Message 9 of 9
denisT.MaxDoctor
it has to send at least MN_SELECTITEM := 0x1E5, and MN_BUTTONUP := 0x1EF
