how to display result?
jackietsteh
jackietsteh
Hi i have a script question here, hoping someone from here could give me some quide, thank you.
format "area=%\n" sum
the format script can display the result in maxscript listener, but it cannot display the result in my rollout label,
may i know is it posible to do that?
Best regards,
Jackie
Best regards,
Jackie Teh
Portfolio: http://www.coroflot.com/jackieteh
Youtube Channel:https://www.youtube.com/user/jackieteh
jackietsteh
Hi i have solved the display result issue after a lot of trial and error, when i think everything is work fine, the script has give me another issue.
when i select a editpoly and use the script, everything is fine, but if i didn't select any object to use the script, it show the error message as below:
Runtime error: EPoly operation on non-Editable Poly: undefined
did anyone know how to solve this?
Best regards,
Jackie Teh
jackietsteh
Thank you, i have solved all the problem here, ciao~
Best regards,
Jackie Teh
