How to determine which mesh elements are touching another?
jeanfA52BL
Message 1 of 10
jeanfA52BL
Hi, I'm at the planning stage of a Max plugin whose first operation would be to determine which objects in a scene are touching each other and count the number of contacts. I'd then like to sort them from least to most neighbors in a hierarchical tree with "leaves" having a value of 1, and twigs, branches and trunk having successively higher and higher values. Think of "Minesweeper" and the number of mines each square is touching....
These objects are typically tangential rather than overlapping (they are walls, floors, ducts etc exported from Revit. They typically have overlapping vertices
I'd like to not use bounding box intersections as it throws false positives in cases of L shaped objects.
Does anyone have any thoughts on this? Would I want to try raycasting from the vertices? Or creating spheres centered on the vertices which could intersect other objects?
Replies (9)
Message 2 of 10
denisT.MaxDoctor
Firstly, let's define - are we talking about MaxScript or c++ SDK plugin?
Message 3 of 10
jeanfA52BL
Ultimately I'm looking to create a plugin but right now I'm stumbling through MaxScript trying to figure out the parts and pieces. I've never coded a line in my life so this is a ground up learning effort involving CodeAcademy, ChatGPT, every Youtube video I can skim through and ... you : )
Message 4 of 10
istan
Message 5 of 10
jeanfA52BL
I didn’t say I was adverse to long responses : )
thanks for the recommendation. I may need to get another MA to read that tho.
Message 6 of 10
denisT.MaxDoctor
So, if I understand correctly, you've decided to skip the small stuff and dive right into learning by solving unsolved problems.
Message 7 of 10
jeanfA52BL
That’s about the size of it yeah. I’m an architect not a software developer. I’m doing this because nobody’s got the  the tool I need and I dont know enough to know if it’s feasible or not.
Message 8 of 10
denisT.MaxDoctor
I believe it's important for everyone to stick to their own area of expertise. Sometimes, as a tools developer, it can be challenging to find truly valuable subjects to work on. If you have an idea for a tool that can significantly simplify or speed up a process, I encourage you to share it with someone capable of bringing it to life.
Message 9 of 10
jeanfA52BL
No doubt, and I largely agree. But I have not been successful so far finding that "someone". Also, the gap between building construction and software development is so large that it's difficult gaining a common vocabulary. I believe I do have an idea for something that could speed up a process. And I think that I now know enough about your area of expertise that I can explain it to a developer coherently. The only way for me to gain that common vocabulary so I can understand what you're saying is to dabble in your field.
If you have a hot second for a wall of text in your DM I can expand a bit on the process I'd like to make happen and you tell me if I'm crazy. And you can critique my grasp of the process. If I make sense and you have any idea who I need to talk to that would be great!
Message 10 of 10
istan
I wanted to point out, that it is impossible to even begin to solve such a task without a detailed specification. You wrote, some vertices already overlap. So you either have to clean up your data first or you might need more or less sophisticated mesh/face/vertex distance measurement algorithms. Each collision software has different goals: accuracy, speed, convex, concave, collision prediction..
