How Can I to know what is more Compatible with more Max version?
alexandre_bisewski
alexandre_bisewski
Hello!
I want to implement a Dictionary.
We have two options:
The Dictionary Maxscript builtin that is compatible with 3ds Max 2017.1 Update and higher.
Or we can use     d = dotnetclass "System.Collections.Generic.Dictionary`2"
Ok, we know that one way is compatible with 2017 version but the other way?
Can I get this information in  some place?
Thank you
denisT.MaxDoctor
no doubt about it... use the built-in MXS dictionary. Unlike the .NET dictionary, the MXS dictionary can be stored in a max scene (file) (because it has Save/Load mechanism). This is a very big benefit.
alexandre_bisewski
Hi Denis.
But strictly based on version, the built-in is better? Because for my implementation I dont need to save. Its is only for temp variables.
denisT.MaxDoctor
For some current tasks, Python dictionaries can be used to temporarily organize data. In general, they are slower than MXS.
I use my own dictionary class, which is very close to the MXS built-in, but mine was implemented eight years earlier.
denisT.MaxDoctor
The built-in MXS dictionary has some limitation that I don't like - you have to define the key type in advance, and you can't mix them later. While this is not a major problem in general, I have encountered situations where it is a bit annoying.
alexandre_bisewski
Your answers give us a light in the right direction. Thank you so much for your attention and sorry my english. I now, is bad...😁
