how can I use the ResetTransform in MaxScript?
xiesansi
xiesansi
Hi!
I try to use Reset Transform for a Non-orthogonal object and export it as .fbx.
it works, Transform matrix has been orthogonalized and each vertex has been recalculated base on orthogonalized Transform.
But when I try use ResetTransform in MaxScript, Only Transform was orthogonalized, Vertex was't recalculated.
So how can I use the ResetTransform I want in MaxScript?
thanks in advance !
leeminardi
For the selected object the following will do.
ResetTransform $
lee.minardi
xiesansi
Hi lee, thanks for your reply,
Unfortunately, this doesn't seem to work for me.
The steps are:
Create a box in 3dmax
Apply rotation and scaling to the box, and turn the box into a non-orthogonal parallel hexahedron.
Export it to fbx, It warned me the box is non-orthogonal.
And import the box in maya, it still looks like orthogonal:
If I click Edit -> Transform -> Reset Transform, export it, and import it in maya, it's non-orthogonal.
That's what I want!
But If I use MaxScript ResetTransform $ , export it and import it in maya.
It's still orthogonal:
How can I keep it non-orthogonal using MaxScript?
Thanks in advance!
denisT.MaxDoctor
I'm assuming the Reset Transform from the "menu" does two things corresponding to MXS as:
	resettransform $
	resetscale $
(it might be another order, but this order is more likely).
xiesansi
hi denis,
I found this works:
ResetXForm
denisT.MaxDoctor
@xiesansi wrote:
I found this works:
ResetXForm
This is a different method. Not what you asked above. This method resets the object's transformation, not the node's transformation. But... if it works for you, then good.
This is what Reset Transform from the menu is:
