How can I split up an array based on number sequences within it?
I start with a large array of ascending number from 1 to 1000 sometimes more. Some of the numbers or groups of sequential numbers in that 1 to 1000 are missing creating gaps.
I need to collect the remaining numbers that are still in sequence to be saved out as their own new arrays.
Anyone have any suggestion on how to do that? I have no idea how you could identify when a gap in the sequence would appear.
thanks
blakestone
The below array splits the complete and incomplete sequence to their own arrays.
I am not sure if this is what you're after?
    local numArray = #(
        "1,2,3,4,5",
        "1,4,5",
        "1,5,6,8,10"
    local completeArray = #()
    local incompleteArray = #()
    for n in numArray do (
        local valid = true
        local f = filterString n ","
        for j=1 to f.count do (
            if f[j] as integer != j then valid = false
            if not valid then exit
        if valid then append completeArray f else append incompleteArray f
Technical 3D Graphic Artist
Autodesk 3dsMax 2015 - Service Pack 4
I may not be explaining my question well.
In my array imagine a large ascending number sequence with numbers missing called myarray. There are numbers missing creating gaps which leave groups of ascending numbers that need to be put in their own seperate arrays. ?
example:
myarray = #(1,2,3,4,5,6,15,16,17,18,19,23,24,25,26,27,28)
In this example I need to generate 3 arrays that look like these
#(1,2,3,4,5,6)
#(15,16,17,18,19)
#(23,24,25,26,27,28)
The only things I will know before running the script is there will be a large ascending number sequence in the array of unknown size and that there will be missing numbers within it. The small remaining grouped sequences that remain need to be placed in new arrays.
blakestone
Maybe this is what you're after?
You can access the multidimensional array like this: groupArray[1][1]
	local numArray = #(1,2,3,4,5,6,15,16,17,18,19,23,24,25,26,27,28)
	local groupArray = #()
	local tempArray = #()
	for i=2 to numArray.count do (
		if (i != numArray.count and numArray[i]-1 == numArray[i-1]) then (
			append tempArray numArray[i]
			continue
		append groupArray tempArray
		tempArray = #()
	print groupArray
In the big array    #(1,2,3,4,5,6,15,16,17,18,19,23,24,25,26,27,28)
In your example code it creates
#(2, 3, 4, 5, 6)
#(16, 17, 18, 19)
#(24, 25, 26, 27)
Looks like it skips the first number of each group.
1 is missing from the first array
15 missing from the second
23 missing from the third
blakestone
You're right, sorry about that!
The below example does what you're after.
	local tempArray = #(numArray[1])
		if i == numArray.count then (
		else if numArray[i]-1 == numArray[i-1] then (
			continue
		tempArray = #(numArray[i])
	print groupArray
awesome! I never would have got that! thank you!
