How can I save and restore docking state and position of a dialog inherit from SceneExplorerDialog...?
arnaud.buiXZM2G
arnaud.buiXZM2G
At Max startup, I created a dialog inherit from SceneExplorerDialog and show it.
It work well and the use can move, resize and dock it where he want.
But how I can save the position and the docking state of the dialog to restore them when the user restarts Max?
Thank you.
arnaud.buiXZM2G
Finaly I found the solution.
To make my SceneExplorerDialog dialog dockable, I manually created a WinFormDockingFrame frame and put the dialog in the frame and I didn't set SceneExplorerDialog.Frame property with the created frame.
I removed theses code and used the SceneExplorerDialog.ShowInFrame() to show the dialog and the dialog docking state is automatically saved and restored by Max.
