getNodeByName in Material editor
Alireza.khoshpayam
Message 1 of 10
Alireza.khoshpayam
Hi!
I want the nodes that have a specific name, for example "fall_map", to be identified and to be able to change their information, for example, to change the front color of that map.
I have no idea, I would appreciate it if anyone could help me!
Replies (9)
Message 3 of 10
Alireza.khoshpayam
Thank you Istan but none of the links work for me
Message 4 of 10
istan
I just checked: they work. AD probably locked you out.. where are you located?
Message 5 of 10
Alireza.khoshpayam
Iran!
I agree with you, probably the reason is the same 😞
Message 6 of 10
istan
But you have access to this board.. fascinating..
Message 7 of 10
denisT.MaxDoctor
You're asking how to find the Slate Material Editor node by name... but what does it matter where it's located? The only fact that this node exists makes sense.
So, it doesn't matter where we look for the node...
Because you want to change a specific node setting, this means you know the class of the node.
Let's find all instances of this class and check that the name matches:
fn findInstanceByName name class:FallOff =
	instances = getclassinstances class
	node = undefined
	for i in instances where (stricmp i.name name == 0) do exit with (node = i)
	node
/*** Usage:
findInstanceByName #fall_map class:FallOff
to compare names, we use the stricmp method, which is case-insensitive and can take either a string or a name type argument.
Message 8 of 10
Alireza.khoshpayam
Thank you Denis! That's exactly what I wanted.
Can we change this code a bit?
to get only the nodes related to the object we selected and have this name, not all the maps with this name.
Message 9 of 10
denisT.MaxDoctor
fn findInstanceByName name class:FallOff target: =
	/* the target optional argument must be a valid object or unsupplied */
	-- if not isvalidobj target do target = unsupplied
	instances = getclassinstances class target:target
	node = undefined
	node
/*** Usage:
findInstanceByName #fall_map class:FallOff target:selection[1]
Try to figure out how the code works... MSX's help is enough for that.
Don't use someone else's code without understanding.
Message 10 of 10
Alireza.khoshpayam
Thank you a lot Denis!
