Announcements
Assign material ID that equal s the Face ID of an object
voller
voller
I'm trying to figure out a way to cycle through an Edit Poly or Editable Poly, where each face gets assigned a Material ID that is equal to the face number. So face 1 would = Mat ID 1, face 2 = Mat ID 2, face 3 = Mat ID 3, and so on.
So I tried chatGPT to get started since I really don't know that much about maxscript and of course that maxscript fails. This is what it told me.
--get the selected object
obj = selection[1]
--cycle through each face of the object
for f = 1 to obj.numfaces do
--get the current FaceSelection
face = getFace obj f
--assign a material ID to the face that is the same as the face IDataChannelEngineClass
setFaceMatID obj f f
It errors at line 8 (face = getFace obj f). Is this even close to a working script?
voller
I think I figured it out, it needed the polyop.setFaceMatID and it didn't need that line that errored out. If there's a more elegant way to do this, I'd be interested in learning why. Like, is there a way to do this if it is an Edit Poly modifier?
obj = selection[1]
--set the object to Editable Poly mode
if classOf obj != Editable_Poly do
obj = convertToPoly obj
-- cycle through each face of the object
--assign a material ID to the Face that equals the Face number
polyop.setFaceMatID obj f f
Serejah
keep in mind that there's an error in mxs documentation and MatId isn't int, but unsigned short, thus you can't have more than 2^16 i.e. 65536 unique id values assigned.
for edit poly it is quite different.
it requires mod panel to be open, object to be selected, subobjectlevel to be active and all of this makes it slow
max modify mode -- required
subObjectLevel = 4 -- required
ep = $.modifiers[#Edit_Poly]
for i = 1 to ep.getnumfaces() do
	ep.SetSelection #Face #{}
	ep.Select #Face #{i}
	ep.SetOperation #SetMaterial
	ep.materialIDToSet = i - 1 -- zero based
	ep.Commit()
@Swordslayeruploaded this thing to unify polyop/edit_poly operations, but I haven't used it myself
https://www.scriptspot.com/3ds-max/scripts/polymodop
voller
This is only needed for objects with up to 4096 faces, usually far less, so it works for my needs.
Thank you for the help!
