Generating and Displaying Geometry in C++
I am sure well advanced questions are the norm on this site but I am hoping that the patrons here will find some room for newbies like me. I am getting started with 3ds max SDK programming. I have a adequate experience in c++/c# and some familiarity with maxscript. I am testing the waters for the viability of a 3D geometry generating application that needs an object oriented programming platform. I am planning to use maxscript for the front end (with Function Publishing). I started off with the various Autodesk help sites and samples but was baffled by how little effort they made to make it easy for a newcomer. After a week of fruitless effort I have come here for help. What I am looking for is a simple starting code that generates a geometry object (say a cube) and displays it in viewport when the plugin is loaded. I believe I can take it from there. Would someone be so gracious? I have scoured the online help and the supplied samples and I assure you that I wouldn't have asked this if I was not desperate.
Thanks.
Just to clarify. ... I have used the code snippets in the Lesson-5 (Geometric Objects) section of the 3ds max sdk help to create an internal mesh object but could not get it to appear in a viewport. The article goes on to more code snippets for mouse interaction function to position the object in a viewport. What I really want is to display the object when the plugin is invoked or through maxscript calls without needing the mouse. What exactly do you do to display a mesh object? What function do you call?
istan
You should rather take a close look to the sample code! It gives you a lot more answers than the SDK doc. e.g. look at boxobj.cpp
And, I would not expect writing useful C++ plugins within a week - without good knowledge of Max! Only if you understood how Max internally works, you will be able to create smoothly running code. You have to deal with topics like C++ vs. MXS / FP, Animation, Undo,..
Thanks for the reply. I have gone through several samples in the maxsdk folder but didn't come across the box object one. (I have the sample pack that comes with 3ds max 2014). I will look into it.
In maxscript you can just type box () and get a cube generated with default values without using the mouse. I don't expect the SDK to be that simple but nevertheless expected an equivalent skeleton project sample in the documentation. What I was hoping for was somebody who had (or can) put together some such code because I assumed it won't be more than a few lines long. Am I correct or is there something huge I am missing?
My end goal is to develop a c++ plugin with a maxscript frontend which generate 3d geometry from a set of user supplied parameters.
I appreciate it if someone can either point me to the right resource or (preferably :)) whip up some code to get me started. I don't really get why it should be so hard on a 3ds max novice who is reasonably equipped with c++/.NET. I have also tried on numerous forums including stackoverflow where I got kicked out for being 'out of topic'. I don't even know what that means.
istan
What is the reason you are not considering just using MXS?There is not much you can't do with MXS. If it's about protection, you could interface to a protected DLL for hiding your top-secret function code.
Thanks for your reply again. My reason for opting for the SDK is I intend to have my own hierarchical object classes representing my 3D objects and I have learnt that you can't do that in maxscript. That is why I needed a n Object Oriented development platform like c++. Besides that I expect the plugin to evolve into a much elaborate tool which processes a considerable volume of 3D data in the future and so I may need the speed advantage. But that is secondary to me right now.
Is there any way you know to display a 3D mesh object without using the mouse call back functionality of the SDK? All the samples including the one you pointed me to use that.
Thanks again.
