Find and delete certain material nodes
andreasVT5XR
Message 1 of 14
andreasVT5XR
Hello
I got an issue that bugs me a lot, and I seem not to be able to find a solution to it.
I want through maxscript to be able to find certain material nodes, f.ex falloff node, and then delete.
To specify; When I delete a node I need the input of the falloff node - let's take color 1 and add that to whatever was the output of the falloff node. This is because I don't want break the material chain.
I know I can find every falloff node in scene with "getclassinstances falloff". But I have no clue on find the output of all of the falloff nodes. I want to find the output so I connect the input to the output.
So basically what I am asking for - I need a script that deletes every falloff node in a scene and reconnect the nodes to whatever slot the fallof was connected to.
My knowledge to maxscript is a bit limited so I would really appericate some explanation rather than just an example. But I take what I get 😉
Thanks for all help.
Replies (13)
Message 2 of 14
denisT.MaxDoctor
fn deleteSmeNodes refs =
	for k=1 to sme.GetNumViews() do
		view = sme.getView k
		view.SetSelectedNodes refs
		view.DeleteSelection()
fn removeFalloff delete:off =
	txs = getClassInstances Falloff astrackviewpick:on
	for_del = #()
	for tx in txs do
		if tx.client != undefined do
			map = if tx.anim.map1 != undefined then tx.anim.map1 else tx.anim.map2
			tx.client[tx.subnum].value = map
		appendIfUnique for_del tx.anim
	if delete do deleteSmeNodes for_del
	for_del
/********* run below code to execute: *********
offs = removeFalloff delete:on
Message 3 of 14
andreasVT5XR
Thanks a lot.
So obviously it works.  But I am not sure exactly how it works, and I really want to learn.
Are you able to give me a quick explanation of this line:
So client is getting the name of the map in front of the falloff? How do subnum and value work?
Message 4 of 14
andreasVT5XR
Hi again @denisT.MaxDoctor
So I thought I had tested this enough, but it seems to crash on me now.
It works fine when the falloff is connected straight to the texmapdiffuse of a CoronaLegacy Material but if there is something in between, let's say a color_correction, it crashes.
Attached a printscreen of the basic setup of the material and a notepad with the error message.
ill paste it here as well. Any idea why?
Thanks again.
deleteSmeNodes()
removeFalloff()
-- Error occurred in anonymous codeblock; filename: D:\Dropbox (3D Estate team)\Prosjekter\Kunder\00_Scripts\01_SuperScript\02_Remove AO\Falloff.ms; position: 476; line: 23
-- Unable to convert: Map #5:Bitmap to type: Integer
-- MAXScript callstack:
-- thread data: threadID:23360
-- [stack level: 0]
-- In tx loop; filename: D:\Dropbox (3D Estate team)\Prosjekter\Kunder\00_Scripts\01_SuperScript\02_Remove AO\Falloff.ms; position: 434; line: 20
-- Parameters:
-- tx: TrackViewPick:"Map: Map #6 ( Falloff )"
-- Locals:
-- map: Map #5:Bitmap
-- Externals:
-- owner: undefined
-- for_del: Free:for_del : #()
-- [stack level: 1]
-- called from removeFalloff(); filename: D:\Dropbox (3D Estate team)\Prosjekter\Kunder\00_Scripts\01_SuperScript\02_Remove AO\Falloff.ms; position: 477; line: 23
-- Parameters:
-- delete: true
-- Locals:
-- txs: #(TrackViewPick:"Map: Map #6 ( Falloff )", TrackViewPick:"reference")
-- for_del: #()
-- delete: true
-- Externals:
-- deleteSmeNodes: Global:deleteSmeNodes : deleteSmeNodes()
-- owner: undefined
-- [stack level: 2]
-- called from top-level
Message 5 of 14
denisT.MaxDoctor
I need to see the falloff.ms file
Message 6 of 14
andreasVT5XR
Hi @denisT.MaxDoctor
Thanks for the reply.
I think haven't done anything to your code posted above - but I have attached the code here.
Message 7 of 14
denisT.MaxDoctor
fn findSubTextures target tex =
	indexs = #{}
	for k=1 to getNumSubTexmaps target where (getSubTexmap target k == tex) do append indexs k
	indexs
	for_del = #()
	for tx in txs do
		tex = tx.anim
		map = if tex.map1 != undefined then tex.map1 else tex.map2
		if iskindof tx.client Material do --and map != undefined do
			indexs = findSubTextures tx.client tex
			for i in indexs do setSubTexmap tx.client i map
		appendIfUnique for_del tex
	for_del
here is an improved version (PRO 😉)... works for your case but may need some testing to be sure
Message 8 of 14
denisT.MaxDoctor
the Color_Correction texture map is a special case. It was interesting to know... Keep testing, there may be some other special cases.
Message 9 of 14
andreasVT5XR
Thank you so much @denisT.MaxDoctor
I will test it and let you know how it works. So far I can't find any errors.
Message 10 of 14
andreasVT5XR
@denisT.MaxDoctor  Hi again.
So I have tested it a bit - and it works great.
I have also tried to understand the code and how "astrackviewpick:on" works.
To me, it looks like I should be able to NOT delete the falloff node if it's connected directly to a texmapdiffuse.
But I am not getting it to work and I am a bit lost on how to do it.
I want to delete and relink every falloff as we can now, but keep the falloffs that are directly connected to a texmapdiffuse.
From what I can see - I want to keep the falloffs that have tx.name == "texmapdiffuse".
Happy Holidays!
Message 11 of 14
Gellvanni
Eu estou encantado com esse "plugin", toda vez que iria exportar do 3ds max para o blender o mapa de falloff acaba se perdendo, fazendo com que o blender não identificasse a textura. Agora, deletando todos os falloff, não preciso ajustar os matérias um a um no Blender. Agradeço por isso!
"I am delighted with this "plugin", every time I would export from 3ds max to blender the falloff map ends up getting lost, causing blender not to identify the texture. Now, by deleting all the falloffs, I don't need to adjust the materials one by one in Blender. I am gratefull for that!"
Translated by Google
Traduzido por [@clacampos] através do Google Tradutor
Message 12 of 14
dqdwaresking
Community Visitor
Community Visitor
Here is a simple code to delete a certain type of node from selected nodes in SME. You can delete any type of node:
activeSelect = #()
fn delete_nodes_type nodeType =
-- local currentView = sme.GetView 1
local currentView = sme.GetView sme.activeView
local selectedNodes = currentView.GetSelectedNodes()
local newSelectedNodes = #()
for each_node in selectedNodes do
if isKindOf each_node.reference nodeType then
append newSelectedNodes each_node.reference
else
append activeSelect each_node.reference
currentView.SetSelectedNodes newSelectedNodes
currentView.DeleteSelection()
currentView.SetSelectedNodes activeSelect
delete_nodes_type CoronaColor
delete_nodes_type ColorMap
delete_nodes_type CoronaAO
delete_nodes_type ColorCorrection
delete_nodes_type Falloff
delete_nodes_type Output
delete_nodes_type CoronaNormal
delete_nodes_type CoronaTriplanar
delete_nodes_type Mix
delete_nodes_type CompositeTexturemap
Message 13 of 14
1652058350
Community Visitor
Community Visitor
Hi, please tell me how to delete dirt nodes,Thanks
Message 14 of 14
1652058350
Community Visitor
Community Visitor
嗨,请问,再删除中间节点时,它不会自动连接两端的节点。
而且对于污垢节点无效,
如果有时间期待您的回复
