Adding to "PYTHONPATH" Environment Variable in ApplicationPlugins
WobiNich
Message 1 of 1
WobiNich
Hi there,
I am developing Application Plugins and I am having a hard time to add to the PYTHONPATH Environment variable in multiple Plugins.
I can add to the path like this:
<EnvironmentVariable Name="PYTHONPATH" Type="PATH" Value="\+;./python modules" />
as stated in the Documentation.
However, when trying to do this in MORE THAN ONE plugin 3ds Max is giving an error message on startup saying:
Duplicate definition for EnvironmentVariable "PYTHONPATH" in package "D:\3dsmax_lib\ApplicationPlugins\PythonUISample\PackageContents.xml" ({bd2cb0e5-fd26-4354-aabf-92f8337f5d71}).
But the documentation says:
"An environment variable can only be defined once, but can be appended or prepended multiple times. Two plug-ins cannot define the same environment variable, but they can append to an already defined environment variable."
So, how can I get this to work on multiple plugins. So, for every plugin I can add to the PYTHONPATH?
Thank you and regards Ben.
Replies (0)
