FFD Control Point to World Space and Back Again
I'm trying to convert FFD points from their custom space to world space and back again, but There is some error in the converting back portion. For some reason 0.83333 gets added to the coordinates. e.g. On control_point_1 it goes from ->
"Orig: "
"Point 1: "
"Final: "
The actual position of my object in world space doesn't matter, it always adds 0.83333 to the coordinate. Can anyone see what I'm doing wrong?
 fn GetRealWorldCoords obj ffd ffdPoint =
print ("Orig: " + ffdPoint as string)
objTM = obj.objectTransform
modTM = (getModContextTM obj ffd) * ffd.lattice_transform.value
modBBMin = getModContextBBoxMin obj ffd
modBBMax = getModContextBBoxMax obj ffd
point1PosWorld = modBBMin + (ffdPoint * (modBBMax - modBBMin)) * (inverse modTM) * objTM
return point1PosWorld
fn GetFFDCoords obj ffd worldPoint =
controlPointPos = (worldPoint - modBBMin) * (inverse objTM) / (modBBMax - modBBMin)
print ("Final: " + controlPointPos as string)
Persistence pays off I guess.
-- This script converts from FFD space to world space and back again.
-- Neil Marshall neil@eightlines.com 12/31/2011
-- If you use this code please credit me.
fn FFDSpaceToWorldSpace obj ffd controlPoint =
if classOf controlPoint != Point3 then
print "Error: You need to pass in a point 3 to properly convert a FFD to world space"
return undefined
objTM = obj.objecttransform
size = modBBMax - modBBMin
thePoint = modBBMin * inverse ffd.lattice_transform.rotation + (controlPoint * size) * modTM * objTM
return thePoint
fn WorldSpaceToFFDSpace obj ffd worldSpace =
thePoint = (worldSpace * (inverse objTM) * (inverse modTM) - modBBMin) / size
return thePoint
while $tester != undefined do
delete $tester
obj = $Box01
animateAll obj.modifiers
print ("Before FFD Space: " + obj.modifiers.control_point_3 as string)
thePoint = FFDSpaceToWorldSpace obj obj.modifiers obj.modifiers.control_point_3
if thePoint != undefined then
print ("WorldSpace: " + thePoint as string)
point name:"tester" pos:thePoint
obj.modifiers.control_point_3 = WorldSpaceToFFDSpace obj obj.modifiers thePoint
print ("After FFD Space: " + obj.modifiers.control_point_3 as string)
