Announcements
Creating toolbars of the same width etc like rappa tools
mitviz
Message 1 of 30
mitviz
would love to create toolbars vertically like i attached but all of them the same width as rappa tools, is this possible?
Replies (29)
Message 21 of 30
mitviz
thank you also!
Message 22 of 30
mitviz
one thing also though, when max opens this empty toolbar thing opens, any ideas to find out what it is'Capture.JPG
Message 23 of 30
Alfred.DeFlaminis
Hello @mitviz,
If I am not mistaken that is the overlay for tablet usage in 3ds Max.  Do you use a tablet?  (Wacom perhaps?)
Best Regards,
Message 24 of 30
mitviz
no i don't have one, how to turn it off?
Message 25 of 30
Alfred.DeFlaminis
Just close it I think.  I may be incorrect about what it is, I don't get it on my work machine but I did on my home machine at one point in the past.  You could check your startup scripts folder to see what is in there, may be a plugin or something that needs it.  (Body objects maybe?)  Can you expand the borders to see whats in it?  (Blank I imagine.)
Best Regards,
Message 26 of 30
mitviz
no clue but yeah its blank
Message 27 of 30
Alfred.DeFlaminis
What scripts do you have in your root/scripts/startup folder?  Maybe for a 3D mouse?   It's harmless and can be closed I believe.
Best Regards,
Message 28 of 30
mitviz
i dont have any like that but i know i can cose it, i close it all the time but its annoying to see it pop up at the start, just one of those things, is it possible to delete some of the scripts i am not sure about from the startup folder and copy them back in to check on by one?
Message 29 of 30
Alfred.DeFlaminis
The worst that can happen is Max doesn't start and you just copy them back in, so it's worth a shot.  You might also check macroscripts.  It's bothering me that I can't put my finger on this one.  Not sure how to search about the window with no name and no content on this end...
I suppose I should suggest resetting user settings just in case.  (Just rename the old ENU folder so if it doesn't help you can just delete the new one and rename the old one back.)  Thanks!
Best Regards,
Message 30 of 30
mitviz
aha, will give it a shot in the morning, try both and see what happens on by one
