Create cylinders from two points and given radius in maxscript
How two creat cylinders from two points and given radius in 3dsmax maxscript? Thank you!
Sorry, I actually only want to know how to proper rotate the cylinder after I create it and move it to point1. I was using the following code to calculate the eulerAngle but apparently the result is a wrong rotating direction.
fn drawCylinderBetweenTwoPoints pt1 pt2=
	vec=pt2-pt1
	he=sqrt((pt1[1]-pt2[1])^2+(pt1[2]-pt2[2])^2+(pt1[3]-pt2[3])^2)
	cy=cylinder()
    cy.pos=pt1
    cy.radius=2
    cy.height=he
    r = sqrt(vec[1]*vec[1] + vec[2]*vec[2] + vec[3]*vec[3])
    t = atan(vec[2]/vec[1])
    p = acos(vec[3]/r)
	euler12=eulerAngles r t p
    cy.rotation=euler12
	return cy
New problem, in some case, the cylinder would perfectly created, but in other cases, there is a problem that is related to Quaternion. The actual rotating angle required does not equal to the angle of two vectors
Swordslayer
Wow that is perfect ok, how could you know that.
