Render and subset not working?
Bob.Bon2000
Bob.Bon2000
Can some1 double check that you guys can get an correct result using this :
mr = mental_ray_Renderer()
renderers.current = mr
SubSnode = Render_Subset_of_Scene_Masking__mi name:"SubS"
mr.Camera_Lens_Shader = SubSnode
shad = renderers.current.Camera_Lens_Shader
shad.enabled = True
shad.material = sceneMaterials["test"] -- Make sure you have test material - car paint preferably
render outputFile:"C:\test.png"
All I'm getting are blank/black  renders. I need to use max quick render to get an actual result? Is this bugged?
MedalHellWay
Ye... don't work. I have try also this (use of a camera):
shad.enabled = True
macros.run "Lights and Cameras" "PhysicalCamera_CreateFromView"
c = $PhysCamera001
w = renderWidth
h = renderHeight
bitm = bitmap w h  filename:(getDir #preview +"\\test.png")
re = render c fileName:dir vfb:on
copy re bitm
save bitm
close bitm
gc light:true
delete c
nothing appears of the new bitmap... I noticed that the building normally shader, it works badly (max2016). I look forward to other users for other tests...
Bob.Bon2000
Uff thatnks for your time and checking it out for me. I thought I was going mental.
This is a terrible news for me 😞
How on earth could it not work sigh. Heart broken.
