Creat Vraymtl from script texture with variables ( Diffuse, glossy, ref, bump )
Message 1 of 1
Hi Everyone,
I am tying to learn something about max Script and Pyton, and I am trying to create a code to make an automatic library material from a folders of textures.
I found some codes like this:
https://forums.autodesk.com/t5/3ds-max-programming/script-to-batch-import-bitmaps-and-create-materia...
After fight some hours with this code I couldn't get any result (I am beginner in scripting), is anyone can help me to create some code?
I make a sample of Vray Mtl with Diffuse bitmap, Reflect bitmap, Glossy Bitmap, Normal bitmap and bump bitmap.
I would like to create a script to make this operation 1000 times and create a different collections of materials.
Also I guess is possible create a variable to detect inside to the texture file name a pattern of words to select the correct texture for each material.
("..Leather01.._d..")
("..Leather01.._r..")
("..Leather01.._g..")
("..Leather01.._n..")
Do you think is possible?
Replies (0)
