OpenEXR : BitmapIO - Render Elements - Enable State
Dan.Sambell
Message 1 of 1
Dan.Sambell
Hi All,
I have hit a bit of a hurdle regarding the OpenEXR : BitmapIO and automating the configuration via MAXscript.
I am trying to automatically add all of the user created V-Ray Render Elements to the EXR file format via MAXscript for purposes of submitting a series of renders through the Batch Render tool.
Below is the code I am using to achieve this:
re = maxOps.GetCurRenderElementMgr() -- get the current render element manager
for n = 0 to (re.numrenderelements() - 1) do
el = re.getRenderElement n
exrSettings.addRenderElementLayerRef el (el.elementname as string) 0 0
I am able to successfully add all of the V-Ray Render Elements to the OpenEXR : BitmapIO however their state is defaulting to "Off". Does anyone know how to enable/turn on each Render Elements state within the OpenEXR : BitmapIO via MAXscript?
I have looked through the MAXscript docs such as the following:
https://help.autodesk.com/view/3DSMAX/2018/ENU/?guid=__files_GUID_FDECDBDE_C741_4CD8_9DE4_F3355490C7...
https://knowledge.autodesk.com/support/3ds-max/troubleshooting/caas/sfdcarticles/sfdcarticles/3ds-Ma...
However I have been unable to solve this issue. I assume it is going to be something extremely simple that I have overlooked but none the less, I would greatly appreciate some help in pointing out my oversight.
Cheers,
Biznitch
Replies (0)
