Control ProOptimizer from C++
Hi!
For the company purposes I am developing a plugin, and, among other things, it is required to set Calculate on every ProOptimizer instance to True, when requested. Is it possible to change Calculate option of the modifier via C++ SDK?
Thanks in advance.
denisT.MaxDoctor
you can do easily...
#1 - collect all ProOptimizer instances (you can find a code how to do it in avg_dlx.cpp
#2 - cast every ProOptimizer node as MAXModifier (or Value) and set its property ("Calculate")  using  set_property method
alternative #2:
#2 - handle every ProOptimizer as Animatable and set its ParamBlock param "Calculate" with SetValue of a corresponding paramBlock (which is first in your case)
