Collapse ModifierStack and keep instances
rartidiello
Message 1 of 10
rartidiello
I need a script for collapsing the modifier stack of all selected objects. Right now the Collapse button under the Utilities panel works but loses the instances.
Thanks.
Replies (9)
Message 2 of 10
denisT.MaxDoctor
Thanks.
something like this...
fn collapseNodes nodes =
	for node in nodes do maxops.collapsenodeto node node.modifiers.count off
collapseNodes selection
or this...
mapped fn collapseNodeToBase node = (maxops.collapsenodeto node node.modifiers.count off)
collapseNodeToBase selection
Message 3 of 10
rartidiello
thanks! works like a charm
Message 4 of 10
rutalauzikaite
Community Visitor
Community Visitor
Could someone help me, try to run those scripts and nothing happens at all 😞
Message 5 of 10
jesped
Can these be updated to work on 2024?
Message 6 of 10
denisT.MaxDoctor
what is not working in 2024?
Message 7 of 10
jesped
I select one object with 'Select Dependents' enabled:
Which selects 185 objects.
I save the script as a .ms file:
I run the script
...and nothing at all happens, with either of the scripts. Am I doing something wrong? 🤔
This is the modifiers stack of the objects:
Ideally, I would want to convert all those 185 objects to 'Editable Mesh', but preserving instances.
Message 8 of 10
denisT.MaxDoctor
first of all the executable code looks as:
for node in selection do maxops.collapsenodeto node node.modifiers.count on
second, dependent nodes are not exactly instances. There are other mechanics to find all instances of a node.
and third, if you do everything right, I'm pretty sure it will still work in 2027 at least.
Message 9 of 10
jesped
Using 'Edit - Select Instances' didn't work either.
But this other script did:
if selection.count != 0 do
local firstInstances = #()
for o in selection do
InstanceMgr.GetInstances o &firstOnly
if firstOnly.count > 1 do
append firstInstances firstOnly[firstOnly.count-1]
if firstInstances.count != 0 do select firstInstances
for obj in $ do
addModifier obj (Edit_Mesh())
for obj in $ do
maxOps.CollapseNodeTo obj 1 off
Thanks anyway.
Message 10 of 10
denisT.MaxDoctor
Great if the code above works... Good luck either way.
