changing Viewport Background with colorMan.
roberto.gagliano
Message 1 of 20
roberto.gagliano
Hi all,
in earlier Versions of Max i used the workflow below to generate 3 buttons which let me change the viewport background color with one click:
- customize UI ... colors ... change viewport background ... click "apply colors" ... save as "white.clrx", "black.clrx", "grey54.clrx
- copy all clrx-files to:
C:\Program Files\Autodesk\3ds Max xxxx\en-US\UI
- open scripting listener
- paste the following line: colorMan.loadColorFile "black.clrx"
- select the whole text and drag it to a toolbar, do the same with: colorMan.loadColorFile "black.clrx" and "grey54.clrx
In 3ds max 2023 this no longer works. Clicking the button produces the attached Macro Script Error Exception.
Unfortunately I have no scripting skills, any help would be appreciated.
thanks in advance
Accepted solutions (4)
Replies (19)
Message 2 of 20
denisT.MaxDoctor
use one of the four block to make a macro:
/**************** BLACK *******************/
	backgroundColor = black
	viewport.EnableSolidBackgroundColorMode on
	s = NitrousGraphicsManager.GetActiveViewportSetting()
	s.UseEnvironmentBackgroundColorEnabled = on
	InvalidateAllBackgrounds()
/**************** GRAY ********************/
	backgroundColor = gray
	-- for dim gray use: backgroundColor = (color 54 54 54)
/**************** WHITE *******************/
	backgroundColor = white
	-- for lite gray use: backgroundColor = (color 200 200 200)
/**************** GRADIENT ****************/
	viewport.EnableSolidBackgroundColorMode off
	s.UseEnvironmentBackgroundColorEnabled = off
Message 3 of 20
roberto.gagliano
Hi Denis,
thanks a lot for the quick help!
It works - but with one limitation:
When launching the macro, the Background color only changes in the perspective view, even if another vieport is active. Even if i maximize one of the other viewports and run the macro, the BG color is changed in the (now invisible) perspective view. If i set the perspective to a camera or to top view the macro still shows the same behaviour.
Am I missing something?
The old macro changed the color in all viewports at once. Basically, changing each viewport separetely would be handy as this way it would be more flexible. But it should be able to adress any viewport, not only the perspective view.
Message 4 of 20
denisT.MaxDoctor
	id = viewport.activeViewportID
	for k=1 to viewport.numViewEx() do
		viewport.activeViewportEx k
	viewport.activeViewportID = id
	for k=1 to viewport.numViews do
		viewport.activeViewport = k
example made for white... how to put a different color, I hope you can guess yourself.
Message 5 of 20
roberto.gagliano
thanks again,
i fiddled around a little yesterday and found out that it has to do with gradient BG in the template file. If the file contains a VP with gradient, only this VP accepts the color change. Then, if i activate any other VP and click the gradient button (with your script), nothing changes in this view at first, but from now on this viewport and the first one (with the initial gradient) accept all the changes at the same time when hitting one of the color buttons. So i first have to set all the viewports to this "invisible" gradient to make the synchronally change color.
the "gradient" script from here on also works but only for the active viewport but at the same time changes the other viewports to black.
if i open up a file without gradient VP (like most of my existing files), the script works as expected.
all this is for your old script, the new one acts similar, but i could not yet find out the "system" behind it.
Anyhow, thanks a lot for yout help! Yout first script is fine for me ...
Message 6 of 20
denisT.MaxDoctor
struct VPT_BackgroundConfig
Apply Button ID:
	0: OK
	1: Cancel
	2: Apply to Active View
	3: Apply to All Views in Active Layout Tab
Background Mode ID:
	0: Synchronize with Display Mode
	1: Use Customize User Interface Gradient Colors
	2: Use Customize User Interface Solid Color
	3: Use Environment Background
	4: Use Files
	debug = off,
	apply = on,
	modeID = 0,
	buttID = 1,
	solidColor = black,
	fn preferenceCallback debug:off =
		hwnd = DialogMonitorOPS.GetWindowHandle()
		if (UIAccessor.GetWindowText hwnd) == "Viewport Configuration" do
			if debug do format "modeID:% buttID:% color:%\n" modeID buttID solidColor
			if iskindof solidColor Color do backgroundColor = solidColor
			back_hwnd = UIAccessor.GetFirstChildWindow hwnd
			mode_hwnd = UIAccessor.GetFirstChildWindow back_hwnd
			for k = 0 to 4 do
				if debug do format "vpmode % >> hwnd:%\t> %\n" k mode_hwnd (UIAccessor.GetWindowText mode_hwnd)
				if modeID == k do UIAccessor.PressButton mode_hwnd
				mode_hwnd = UIAccessor.GetNextWindow mode_hwnd
			butt_hwnd = UIAccessor.GetNextWindow back_hwnd
			for k = 0 to 3 do
				if debug do format "button % >> hwnd:%\t> %\n" k butt_hwnd (UIAccessor.GetWindowText butt_hwnd)
				if buttID == k do UIAccessor.PressButton butt_hwnd
				butt_hwnd = UIAccessor.GetNextWindow butt_hwnd
			UIAccessor.SendMessageID hwnd (if apply then #IDOK else #IDCANCEL)
		true
	fn setupBackground mode: action: color: =
		if mode != unsupplied do modeID = case mode of
			    #sync: 0
			#gradient: 1
			   #solid: 2
		 #environment: 3
			    #file: 4
		     #default: 0
		if action != unsupplied do buttID = case action of
			    #ok: 0
			#cancel: 1
			 #actve: 2
			   #all: 3
			default: 1
		if color != unsupplied do solidColor = color
		local enabled = DialogMonitorOPS.Enabled
		DialogMonitorOPS.RegisterNotification this.preferenceCallback id:#vptBackgroundConfig
		DialogMonitorOPS.Enabled = true
		max vptconfig
		DialogMonitorOPS.unRegisterNotification id:#vptBackgroundConfig
		DialogMonitorOPS.Enabled = enabled
		ok
global _bcfg = VPT_BackgroundConfig()
--> ACTIVE VIEW GREEN:
_bcfg.setupBackground mode:#environment action:#active color:green
--> ALL VIEWS ORANGE:
_bcfg.setupBackground mode:#environment action:#all color:orange
--> ALL VIEWS GRAIENT:
_bcfg.setupBackground mode:#gradient action:#all
Reloading a color file (*.clrx) during a MAX session is generally not recommended. When you upload the clrx file, you are reloading ALL color settings for the MAX UI. Some tools use their own custom colors and apply them to custom UI elements. You can't know those colors, so you overwrite them with some default values. For some of my old tools, I used custom colors, but now I use a different mechanism for this because some developers have overwritten my settings with inept use of clrx files.
Message 7 of 20
denisT.MaxDoctor
the attached error exception says that the macro has a syntax error, namely "lower quotes" at the beginning of the filename. (,,filename''). Such "localization" is not allowed by the MaxScript syntax.
Message 8 of 20
roberto.gagliano
thanks a lot again!
this seems very comprehensive ... will take me some time to check it out
Message 9 of 20
roberto.gagliano
i remember having this before and writing me a note about this.
i paid extra attention to paste it the correct way, but seems there has been some "hidden conversion"
Message 10 of 20
roberto.gagliano
hello denisT.MaxDoctor,
i´ve been using your script from Message #4 from ‎11-21-2022 10:43 AM for some days.
Changing the Viewport Background Color simultaneously changes the Render Environment´s Background Color, which is not conveniant as it also affects the "Default Shading" behaviour of viewports set to "High Quality".
Using my old colorMan-scripts does not do so.
I could not yet figure out how to use your advanced script from Message #6 from ‎11-22-2022 10:45 AM.
Does it show same same behaviour regarding Render Environment settings?
Message 11 of 20
denisT.MaxDoctor
global VPT_BackgroundConfig
	struct _vpt_backgroundconfig
		modeID = 0,
		buttID = 1,
		solidColor = black,
		fn preferenceCallback apply:on =
			--format "modeID:% buttID:% color:%\n" modeID buttID solidColor
			title = uiaccessor.GetWindowText hwnd
			--format "hwnd:% text:%\n" hwnd title
			if iskindof title String and matchpattern title pattern:"Viewport*Configuration" do
				local TCM_SETCURFOCUS = 0x1330
				local backgroundTabIndex = 1
				children = uiaccessor.GetChildWindows hwnd
				for child in children do
					if ((uiaccessor.GetWindowClassName child) == "SysTabControl32") do
						exit with (uiaccessor.SendMessage child TCM_SETCURFOCUS backgroundTabIndex 0)
				back_hwnd = (windows.getChildHWND hwnd "Viewport Background")[1]
				mode_hwnd = uiaccessor.GetFirstChildWindow back_hwnd
				for k = 0 to 4 do
					--format "vpmode % >> hwnd:%\t> %\n" k mode_hwnd (UIAccessor.GetWindowText mode_hwnd)
					if modeID == k do
						exit with (uiaccessor.PressButton mode_hwnd)
					mode_hwnd = uiaccessor.GetNextWindow mode_hwnd
				butt_hwnd = (windows.getChildHWND hwnd "OK")[1]
				for k = 0 to 3 do
					--format "button % >> hwnd:%\t> %\n" k butt_hwnd (UIAccessor.GetWindowText butt_hwnd)
					if buttID == k do uiaccessor.PressButton butt_hwnd
					butt_hwnd = uiaccessor.GetNextWindow butt_hwnd
				uiaccessor.SendMessageID hwnd (if apply then #IDOK else #IDCANCEL)
			true
				#gradient: 1
				  #custom: 2
			 #environment: 3
					#file: 4
				 #default: 0
					#ok: 0
				#cancel: 1
				#active: 2
				   #all: 3
				default: 1
			max vptconfig
			DialogMonitorOPS.Enabled = enabled --false
			ok
		action_00 =
			macroScript VPT_SUPER_BLACK
				category:"with denisT"
				buttonText:"SUPER BLACK"
				toolTip:"View Background: SUPER BLACK (+SHIFT - ALL)"
				autoUndoEnabled:off
				silentErrors:off
				local bcfg = undefined
				local bgcol = black
				local setts	= undefined
				fn is_enabled = isstruct (bcfg = ::VPT_BackgroundConfig)
				fn v_settings = NitrousGraphicsManager.GetViewportSetting (if (i = viewport.activeViewportId) != undefined then i else -1)
				on isEnabled do (is_enabled())
				on isChecked do (setts = v_settings()) != undefined and
					setts.UseEnvironmentBackgroundColorEnabled and (backgroundColor == bgcol)
				on execute do if is_enabled() do
					act = if keyboard.shiftPressed then #all else #active
					bcfg.setupBackground mode:#environment action:act color:bgcol
		action_01 =
			macroScript VPT_BLACK
				buttonText:"BLACK"
				toolTip:"View Background: BLACK (+SHIFT - ALL)"
				autoUndoEnabled:off
				silentErrors:off
				local bgcol = (color 1 1 1)
		action_02 =
			macroScript VPT_DARK_GRAY
				buttonText:"DARK GRAY"
				toolTip:"View Background: DARK GRAY (+SHIFT - ALL)"
				autoUndoEnabled:off
				silentErrors:off
				local bgcol = (color 32 32 32)
		action_03 =
			macroScript VPT_CUSTOM
				buttonText:"CUSTOM"
				toolTip:"View Background: CUSTOM (+SHIFT - ALL)"
				autoUndoEnabled:off
				silentErrors:off
					bcfg.setupBackground mode:#custom action:act
		action_04 =
			macroScript VPT_DEFAULT
				buttonText:"DEFAULT"
				toolTip:"View Background: DEFAULT (+SHIFT - ALL)"
				autoUndoEnabled:off
				silentErrors:off
					bcfg.setupBackground mode:#default action:act
		action_05 =
			macroScript VPT_GRADIENT
				buttonText:"GRADIENT"
				toolTip:"View Background: GRADIENT (+SHIFT - ALL)"
				autoUndoEnabled:off
				silentErrors:off
					bcfg.setupBackground mode:#gradient action:act
		/* -- Solid Color Template
		action_<index> =
			macroScript VPT_<COLOR_NAME>
				buttonText:"<COLOR_NAME>"
				toolTip:"View Background: <COLOR_NAME> (+SHIFT - ALL)"
				autoUndoEnabled:off
				silentErrors:off
				local bgcol = color <R> <G> <B> -- or color built-in name
		on create do
			callbacks.removeScripts id:#VPT_BackgroundConfig
			callbacks.addScript #activeViewportChanged "updateToolbarButtons()" id:#VPT_BackgroundConfig
	VPT_BackgroundConfig = _vpt_backgroundconfig()
	ok
save this code in any MS file with a name that makes sense to you... for example: "vpt_background.ms"
and put in any autoload max directory...
let's do it:
...\Program Files\Autodesk\3ds Max ***\stdplugs\stdscripts\vpt_background.ms
after restarting MAX you will see in Customize User Interface -> Toolbars -> Category: with denisT
and several View Background items - BLACK, CUSTOM, DARK GRAY etc...
Names correspond to the code's macro actions.
If you make macro buttons, clicking the button sets the background for the active viewport by default to the specified state, but if you click with SHIFT it will do for ALL viewports.
If you need to add your own color - just add a new action to the code... (see "Solid Color Template" in the code above)
Message 12 of 20
roberto.gagliano
WOW!! Thanks for the Help and the comprehensive explanation.
I did everything according to your instructions.
Now, when clicking one of the buttons: the "Vieport configuration" dialog pops up, but nothing else happens, not even if i click "OK" on the dialog. Is this intentional? should there be some changes made in the dialog before confirming "OK".
thanks again for your patience with my unknowledgment!
Message 13 of 20
denisT.MaxDoctor
no... something is going wrong...
it has to open config dialog, set up the background mode, and close it...
take the latest code... and try again.
what MAX version do you use?
Message 14 of 20
roberto.gagliano
i used your latest code (message #11 from ‎12-01-2022 07:49 PM)
Max-version is also the latest, downloaded and installed on 11-14-2022 (3ds Max 2023.2.2)
Message 15 of 20
denisT.MaxDoctor
I updated message #11. The attached code now works in 3ds Max 2023.
Message 16 of 20
roberto.gagliano
I used your new code and also generated a "RED" button based on your template. The background now changes, but not as expected.
Is there a difference between the background set in the viewport configuration and the background set in the render environment? As i pointed out earlier, the render environment should not be changed.
I attached some screenshots to illustrate what happened:
The "SUPER BLACK" button works as expected. All the others switch the render environment which results in strange behaviour in shaded viewports using "High Quality" (and also in renderings, I suppose).
Message 17 of 20
denisT.MaxDoctor
I showed all possible ways to change the viewport background, but it seems that you need the simplest, although in my opinion the less useless. Here is the last attempt... There is no more ways to change background!
/**************** CUSTOM GRADIENT (RED-YELLOW) ****************/
	colorMan.setColor #ViewportGradientBackgroundTop [0.1,0,0]
	colorMan.setColor #ViewportGradientBackgroundBottom  [0.1,0.1,0]
	s.UseViewportBackgroundEnabled = off
/**************** DEFAULT GRADIENT ****************/
	def_top = colorMan.getDefaultColor #ViewportGradientBackgroundTop
	def_bot = colorMan.getDefaultColor #ViewportGradientBackgroundBottom
	colorMan.setColor #ViewportGradientBackgroundTop def_top
	colorMan.setColor #ViewportGradientBackgroundBottom def_bot
/**************** CUSTOM ORANGE ****************/
	colorMan.setColor #ViewportBackground (orange as point4)
	s.UseViewportBackgroundEnabled = on
/**************** CUSTOM DEFAULT ****************/
	def = colorMan.getDefaultColor #ViewportBackground
	colorMan.setColor #ViewportBackground def
Message 18 of 20
roberto.gagliano
Great, thanks!
Also thanks for your patience.
Just to let you understand, why it had to be like this for me:
I use the buttons to change the BG color for all VPs at once. Then i make one screenshot of all 4 VPs for quick customer feedback. The screenshots are arranged, scaled and cropped in Indesign and output as pdf, all on a white background. For additional pages with varying designs i simply make a new screenshot, and change the file links in Indesign.
To have the same model appearence for all VPs (shading with Standars or High Quality) it must be avoided that the BGcolor is set as Render Environment Color.
One last question: I use your line
" colorMan.setColor #ViewportBackground [0.19,0.19,0.19]"
to set custom colors or shades of gray. Is there a way to enter the color as RGB?
thanks in advance!
Message 19 of 20
denisT.MaxDoctor
colorMan.setColor needs a point3 (or point4) value (where a component is from 0.0 to 1.0).
you can convert RGB to point4, for example
colorMan.setColor #ViewportBackground (white as point4)
colorMan.setColor #ViewportBackground ((color 32 32 32) as point4)
  or to point3:
colorMan.setColor #ViewportBackground (white as point3 / 255)
colorMan.setColor #ViewportBackground ((color 32 32 32) as point3 / 255)
Message 20 of 20
roberto.gagliano
Thanks again!
