C++ QT anomalies
C++ QT anomalies
istan
Advisor Advisor
C++ QT anomalies
istan
Are there any C++ programmers left?
Max aparently uses a modified QT version. Many widgets cannot use stylesheets anymore.
Is there a way to get the original QT appearance back again - at least for my plugins?
e.g.
a) doublespinners use smaller up/down buttons
b) treeview header is bigger and cannot be changed
c) all hover functions in general cannot be tuned (i.e. I want to highlight the whole checkbox text instead of just the box)
Unfortunately AD did also not add the changed QT source code to the debug release, to see what they all changed..
denisT.MaxDoctor
e.g.
Are you talking about rollout controls? All rollout controls are still winapi, but now they are drawn by Qt. Thus, there is no "real Qt" control behind, and there is no way to change the appearance.
istan
I use no rollouts so far. But I could work around some issues by setting stylesheets at runtime. This way, some of the Max changes can be undone again. For spinner controls I have no solution yet - afaik they don't use stylesheets for the buttons.
denisT.MaxDoctor
... they don't use stylesheets for the buttons.
who doesn't use stylesheets? Where?
of course for every Qt widget you can set stylesheet
istan
i think qdoublespinners up/down buttons cannot be changed by stylesheets - esp. in their size..
denisT.MaxDoctor
this is what you can do with QSpinBox
https://doc.qt.io/qt-5/stylesheet-reference.html
istan
Yep - You were right! Thanks. It's also working!
BTW: Happy New Year!
