C++ SDK (Possibly CatAPI) Animation Controller Access Question
I would like to access the CAT animation layer transformation/rotation key controllers the way I can using MAXSCRIPT. For example:
$.transform.controller.LayerTrans.controller.CATMotion_Layer1.controller.Rotation.controller.Z_Rotation.controller.keys[1].value = xx.xx
I've traveled down some C++ API (and CatAPI) rabbit holes but can't seem to get anywhere near what I need to expose. Doing it with script or a hybrid is not what my client wants and would not work with the rest of the plugin I'm developing. Anyone have any examples or directions that would help me achieve this?
Thanks!
denisT.MaxDoctor
Why do you think the CAT API is available at all? As far as I know, we only have a couple of published to MXS CAT interfaces ...
I don't really like CAT, but I'm curious to know if I missed anything about accessing CAT.
Ok then! I guess that answers that.
So I suppose the reference in the 3ds Max Developer Help isn't supposed to be used?
I tend to read and follow alot... that's why I get into these quagmires from time-to-time.
denisT.MaxDoctor
CAT controllers are made as simple Animatable... so you get access to all their subAnims (including names for double-check).  To get controller you should use GetReference.
So the plan looks as (pseudo code):
tmnode > GetTMController()
LayerTrans = tm > SubAnim(0)
LayerTrans .controller = (ReferenceTarget*)LayerTrans
CATMotion_Layer1 = LayerTrans .controller > SubAnim(0)
CATMotion_Layer1.controller = (ReferenceTarget*)CATMotion_Layer1
after that all is simple.. because it's simple PRS
as you can see you don't need CAT API here
if you want to be sure that you work with CAT controls, you can check sub anim names
Thank you for that. I can see a path I haven't gone down before. Will work with this and see what happens.
