3dsMax SDK project build with Visual Studio problem.
1732193753
Message 1 of 11
1732193753
when i want to build a 3dsMax SDK project with Visual Studio 2022,i meet an error, the error show's up when i click finish. Error processing template file:D:\maxsdk\howto\3dsmaxPluginWizard\Templates\1033\PRIMARY_CLASSDESC.txt i don't know how to fix the problem to meke sure i can build 3dsMax SDK project with Visual Studio 2022. could anyone help me to fix it?
Replies (10)
Message 2 of 11
istan
Does the file exist ?
"D:\maxsdk\howto\3dsmaxPluginWizard\Templates\1033\PRIMARY_CLASSDESC.txt"
Message 3 of 11
1732193753
yes,the file it's in that folder.
Message 4 of 11
1732193753
i can see the 3dsMax SDK template in the Visual Studio2022,but when i click the finish button,the error show's up.
Message 5 of 11
1732193753
this is file"PRIMARY_CLASSDESC.txt"
Message 6 of 11
1732193753
Thanks everyone. problem solved.
Message 7 of 11
jan.huebnerMH7GF
I have just the same problem.
The error is: "Error occurred processing template file: c:\Program Files\Autodesk\3ds Max 2020 SDK\maxsdk\howto\3dsmaxPluginWizard\Templates\1033\MASTER_PARAMBLOCKDESC.txt
With 2020 & 2025 SDK in VS2022.
There file is there.
What's the solution?
Message 8 of 11
1732193753
the problem is cause by the wrong version of vs and sdk,if you want to use the 3dsMaxPluginWizard to build project,you better use the version required by autodesk.my solution is use those samples to build project myself,there're many samples in sdk.
Message 9 of 11
jan.huebnerMH7GF
Hmm, thanks for the reply.
MAX 2025 SDK does work with VS2022. And so should the Wizard.
I also can work on and build plugins for MAX2020 with VS2022.
The Plugin Wizard readme.txt of the 2025 SDK, to setup the Wizard, even describes settings for VS2022. (e.g. VsWizardEngine.17.0 and the different folder location for the vcprojects, due to VS2022 being 64bit now.)
The problem is that I want to create an Atmosphere plugin and there is hardly anything in the Sample projects except the stone age old Fog sample from MAX2 or 3....
Also the SDK docu is very limited on that topic.
Message 10 of 11
1732193753
i think you should ask Autodesk official about this issue,they may provide you some suggestions.
Message 11 of 11
jan.huebnerMH7GF
Yea, thanks.
I will post here when I get a solution....
