3DS Max 2025 The Menu System
dev1SNH6A
Observer Observer
dev1SNH6A
Observer
Observer
Hi Does anyone tried the new Menu Editor in 3ds Max 2025?
I tried the demo code it creates the menu in the menu editor but it doesn't show in the main menu.
This is the demo code for standard menu. when I run it this is what I get
As you can see it doesn't show it here even I put the script in startup.
Thank you in advance.
larryminton
Having the script in startup results in the script being run too late. The #cuiregistermenus has already occurred. It occurs between steps 3 and 4 of the startup sequence shown in https://help.autodesk.com/view/MAXDEV/2025/ENU/?guid=GUID-615D14FB-0F2D-4801-B381-1128C4128C70.
Larry Minton
Principal Engineer, M&E-Design Animation
dev1SNH6A
Observer
Observer
Hi Larry,
That solved my Problem Thanks!
Cheers!
